oil feed bolt broken off in engine....suggestions
Old Jun 30, 2003 | 01:00 PM
VTgringo's Avatar
Default oil feed bolt broken off in engine....suggestions
while installing my oil feed line today i managed to break off the bolt that screws into the oil pressure sensor hole on the back of the block. Would it be impossible to get out with the engine still in the car? If not, how would I go about getting it out? This is so shitty...i was so close to being boosted. Thanks for the help
Old Jun 30, 2003 | 01:11 PM
VTgringo's Avatar
Default Re: oil feed bolt broken off in engine....suggestions (VTgringo)
Come on guys, i really need some help with this one. Anyone have experience with something like this?
Old Jun 30, 2003 | 01:14 PM
ion_four's Avatar
Either, drill it out the best you can and retap for the same or larger size (though you risk getting some metal in the engine.
OR, get a reverse drillbit (I think they might sell them at sears?) and it should take it out.
I think FIRST I would try to somehow slot it and back it out with a screwdriver, then try to find a reverse drill bit, THEN if you can't, drill it out for real with a drill bit the same size as the piece that's broken off, not including the threads (so slightly smaller) and then try to tap it out the same size.
Good luck man.
Old Jun 30, 2003 | 01:16 PM
93LSivic's Avatar
Default Re: oil feed bolt broken off in engine....suggestions (ion_four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">OR, get a reverse drillbit (I think they might sell them at sears?) and it should take it out.
Good luck man. </TD></TR></TABLE>
I would attemp this first, definetly. If not then your gonna have a **** hole of a time repairing the block.
Old Jun 30, 2003 | 01:18 PM
VTgringo's Avatar
thanks for the help.....i'm thinking that i'll have a hell of a time getting a drill back to that bolt.... Ugh, this sucks.
Old Jun 30, 2003 | 07:38 PM
VTgringo's Avatar
I got it out with a screw extractor set......phew, i was almost knee deep in ****
myuglycivic
Aug 1, 2005 06:05 PM
foz
Welding / Fabrication
21
Jun 13, 2005 04:47 PM
VTgringo
Jun 30, 2003 07:36 PM
kanzenr91si
Dec 6, 2002 11:25 PM
