Do I have an LSD?
Old Jun 30, 2003 | 12:21 PM
servion's Avatar
Default Do I have an LSD?
When I got the tranny, it was supposed to come with a quaife. I looked through the diff, and sure enough you can see straight through it.
If I jack the front of the car off the ground and put it in gear, if I turn one wheel the other turns the opposite direction. If a buddy tries to turn one side while I'm turning the other, it won't go (i.e., while in gear one wheel always turns the opposide direction when the car's up in the air).
Is this a good method for determining if a tranny has an LSD?
BUT, I broke an axle at the track, and the car wouldn't budge. Can't you drive an LSD equipped car on one axle?
Old Jun 30, 2003 | 01:31 PM
B18PoweredCivic's Avatar
Wel if you can look right through the diff you have LSD...And you can still break axles with LSD but i wont recommend driving on one axle
Old Jun 30, 2003 | 01:57 PM
servion's Avatar
Default Re: (B18PoweredCivic)
I defeinitely wouldn't want to drive on one, but I thought that the car would still drive with one broken axle
Old Jun 30, 2003 | 02:57 PM
VTECorona's Avatar
Default Re: (servion)
My 92 Prelude S did that too (turn one wheel, other wheel turns in other direction) and I highly doubt it was LSD equipped.
Old Jun 30, 2003 | 06:31 PM
Mohudsolo's Avatar
Default Re: (VTECorona)
A quaife needs at least a small amount of resistance from one wheel to get torque over to the other. That is why the rally guys don't use them. One wheel in the air and the other does not get power. So, with one axle broken, the car will not move.
Old Jul 1, 2003 | 07:26 AM
servion's Avatar
Default Re: (Mohudsolo)
Whew... that a relief.
So... is having the car off he ground and spinning one wheel a bad way to determine if a car has an LSD?
Is a OEM honda LSD able to drive with one axle busted?
Old Jul 1, 2003 | 07:33 AM
sslude's Avatar
if you can see straight through he diff. then its an LSD. didnt you notice taht your handling was better or anything like that?
Old Jul 1, 2003 | 08:28 AM
servion's Avatar
Default Re: (sslude)
Well, I thought that I did when I got it... but now I'm used to it.
I was worried that it was malfunctioning somehow because I couldn't drive with only one axle. Is there any wasy that quaife could "break" and act like an open diff?
Old Jul 1, 2003 | 11:59 AM
dc2dragster's Avatar
From: eastside of the beach, westside of the coast, Long Beach, CA, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">
Is a OEM honda LSD able to drive with one axle busted?</TD></TR></TABLE>
yes that is a bad way to determine if u have lsd.
if u can look str8 thru it then u have lsd but if there is a pin in it then its not.
another way to tell if u have lsd is to do a burnout and see if both wheel spin.
and yea u can drive on one axle with lsd but its not recommened
nextproject97
Transmission & Drivetrain
Apr 6, 2009 06:47 PM
killrB
Dec 4, 2007 10:21 AM
mike93eh2
Nov 20, 2007 09:28 PM
jep
Jun 12, 2006 02:55 PM
LSegHatchy
Oct 28, 2004 12:20 PM
