Do I need to take any special precautions with my new setup?
Old Jun 30, 2003 | 10:38 AM
MaxBoost's Avatar
New User
Default Do I need to take any special precautions with my new setup?
I'm assembling this motor this month, and I want to know with the parts I have are their any special precautions I need to take? Such as:
1) Piston-to-valve clearance's? Do I need to clay the motor, or should it be fine?
2) Should I shoot for .12-.13 factory piston-to-wall clearance?
3) What about valve-to-valve clearances with my big cams? How do I make sure everything will run right? What should or shouldn't I worry about?
4) Install height on the valvesprings?
5) Should I run factory ring gaps, or what JE reccomends? or any other gaps??
6) Also I have my choice of a JG Victor-X or a Skunk2..which one will be best? Is my setup big enough to justify a JG?
7) Someone told me that GE blocks need to have some additive added to the cooling system to stop them from leaking? Is this true? If so what do I need to buy?
I'm clueless when it comes to building motors, I just want to make sure that I have nothing to worry about. Also I'm not running adj. cam gears for safety sake.
<u>Ok, here's the new setup:</u>
B18b Block
GE Sleeved
Custom JE 85mm Pistons w/ 12.3:1 & Relocated Wrist Pin .137 swain coated
Custom Long Eagle Rods w/ Upgraded 10mm Rod Bolt
B18C5 Head (not ported but mildly cleaned up and portmatched to headers and intake manifold)
Fresh OEM 3-angle valvejob w. new ITR Valves
EF-1 Valvesprings
EF-1 Ti Retainers (TiN Coated)
EF-1 M24E Cams
JG Intake Manifold
70mm RPM Service ThrottleBody
HeaderTech Header, 3"QTEC, stock exhaust
B16 Tranny, ACT Clutch & Flywheel (8.8lbs)
Old Jun 30, 2003 | 01:40 PM
MaxBoost's Avatar
New User
Default Re: Do I need to take any special precautions with my new setup? (MaxBoost)
Bump!
k24es1
K Series
May 28, 2014 08:50 PM
tegdude227
Mar 30, 2007 05:02 AM
crvtkllr
Oct 12, 2006 01:49 PM
tyflip2
Nov 11, 2003 07:47 PM
