What compression for Z6 9.0 Pistons in a D16Y8?
Old Jun 30, 2003 | 09:44 AM
swrdply400mrelay's Avatar
Default What compression for Z6 9.0 Pistons in a D16Y8?
Like the topic says, what would be the compression ratio if you were to use 9.0:1 D16Z6 pistons into a D16Y8 engine? Thanks
Mike
Old Jun 30, 2003 | 07:26 PM
Default Re: What compression for Z6 9.0 Pistons in a D16Y8? (swrdply400mrelay)
bump
Old Jul 1, 2003 | 01:59 PM
Nobody knows?
Old Jul 2, 2003 | 09:55 AM
Somebody must be a D series genius.
Old Jul 2, 2003 | 11:21 AM
Sonny's Avatar
It will up the compression ratio by about .3 points. The D16Z6's combustion chamber has a volume of 34.6cc. The D16Y8 has a volume of 32.8cc. The headgasket thicknesses and bore/stroke of the 2 engines is the same.
Sonny
Old Jul 2, 2003 | 01:00 PM
Default Re: What compression for Z6 9.0 Pistons in a D16Y8? (Sonny)
Thanks Sonny, you genius
hatchBK4life
13
Nov 14, 2010 08:03 PM
fv8s
Jul 31, 2010 08:46 PM
alexsracing
May 1, 2006 07:25 AM
SpoonPoon
Nov 27, 2003 08:44 PM
