Anyone ever use JDM B16 pistons with a B18 block?
Old Jun 30, 2003 | 08:55 AM
TedR719's Avatar
Default Anyone ever use JDM B16 pistons with a B18 block?
I currently have a JDM B16A (SiRII) motor in my hatch. I wanna swap out the block for a b18c1 and bump up the compression a bit. Now I went to http://www.c-speedracing.com to use their c/r calculator and I figured out if I had a b16 head with a b18c1 block and the jdm b16 pistons it would yield me a c/r of 11.6 and thats the c/r that I want.
Anyone have this setup? If so what rods did you use (b16 or b18)? This would be alot cheaper than buying a brand new set of pistons when I do get my block.
Old Jun 30, 2003 | 08:59 AM
2000blackgsr's Avatar
Default Re: Anyone ever use JDM B16 pistons with a B18 block? (futuresi)
I don't mean to be a dick, but search for poor man's type r (b18c block, b16 head and pistons), since that is basically what you are describing. If I knew the answer for sure I would let you know but I believe you can use the stock b18c rods.
Old Jun 30, 2003 | 09:07 AM
TedR719's Avatar
Default Re: Anyone ever use JDM B16 pistons with a B18 block? (96coupe)
Ahh so thats what it is. Thanks just wanted to get more info before I spend any $$
Old Jun 30, 2003 | 11:20 AM
lsvtecracer's Avatar
You can use your stock rods with the b16 pistons.
Cheez-It
Jul 19, 2006 04:32 PM
markaria
Oct 10, 2004 06:23 PM
rusteds2k
Aug 17, 2004 02:08 PM
sir91
12
Apr 22, 2004 10:54 AM
Honduhhh
Jul 22, 2002 01:08 AM
