Your best bone-stock 1/4 times
Old Jul 26, 2001 | 10:06 PM
Toda Party's Avatar
Default Your best bone-stock 1/4 times
?? I have no time to get down to the track, and people always ask me what I run and i say, i dunno, i never have. So i figure i'll avergae everyone out and say "well my car runs anywhere from 14.xx -15.xx...right? I'm thinking like 14.7 or so??
Old Jul 26, 2001 | 11:13 PM
JDM R98's Avatar
Default Re: Your best bone-stock 1/4 times (NBP ITR 01-622)
14 flat last time i ran it..but i just got new mods..expecting 13s..
Old Jul 26, 2001 | 11:18 PM
Type Goch's Avatar
New User
15.4 at palmdale 92+ degree weather. First time. Street tires.
Old Jul 27, 2001 | 12:09 AM
Louie's Avatar
What would Chente do?
Default Re: Your best bone-stock 1/4 times (Type Goch)
not bone stock but close...cai only....14.77.
Old Jul 27, 2001 | 04:11 AM
TypeR 1159's Avatar
New User
Default Re: Your best bone-stock 1/4 times (vagoITR)
Bone stock I ran 14.71@96. 01 PY Type R
Old Jul 27, 2001 | 04:35 AM
fitzuni's Avatar
New User
Default Re: Your best bone-stock 1/4 times (TypeR 1159)
14.71 @95.98
2.4 60FT
2001 # 13 ITR PY
Old Jul 27, 2001 | 05:08 AM
TypeR 1159's Avatar
New User
Default Re: Your best bone-stock 1/4 times (fitzuni)
het fitzuni...that is almost exactly the same Et .....except my 60' was 2.21
Old Jul 27, 2001 | 05:55 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
If you've never been to the track before, you should tell people you run in the 16's, because a lot of people run shitty their first time out if they have no dragstrip experience.
Old Jul 27, 2001 | 06:07 AM
AWDSOME's Avatar
Default Re: Your best bone-stock 1/4 times (Ross1013)
14.764@94.72 with full interior and all belts on.
The temp was about 75-80 degrees.
It took me a couple on months to get to that time. Usually, I see people (beginners) make their first run in the high 15's and low 16's, but by the end of the night they are consistently at 15.2-15.3
Old Jul 27, 2001 | 06:14 AM
jond's Avatar
Default Re: Your best bone-stock 1/4 times (Hyper165)
So whats the secret? I haven't draged my ITR yet.
Old Jul 27, 2001 | 02:07 PM
Toda Party's Avatar
Default Re: Your best bone-stock 1/4 times (jond)
I was pretty dead on w/ the 14.7 call...well if i tell ppl i run 16s, its pretty embarassing...i'll just continue to say "i've never run before" till i do, but now at least i can say "i've never run before BUT a good driver will run about 14.7 in this car, so be afraid, be very afraid u damn riced out automatic 1996 mitsubishi galant with glowing windshield washer fluid nozzles and super huge wing!"
Old Jul 27, 2001 | 02:09 PM
JohnnyBoy's Avatar
A GOOD driver can do 14.4 STOCK. The best I've done is 14.4@98 with an AEM CAI. STOCK I think was 14.6 or 7
Old Jul 27, 2001 | 02:15 PM
Toda Party's Avatar
Default Re: Your best bone-stock 1/4 times (JohnnyBoy)
THat's what i said, a Good driver. I want to see how good iam. Damn lack of time. Anyone from the Tri-State NY metro area wanna go down to a track sometime before the end of auguast? Island dragway maybe?
Old Jul 27, 2001 | 02:20 PM
Ladies Man's Avatar
New User
with just an intake and open header 14.00 flat ohh yeah on slicks
now I'm looking at 12's secrets are to be released once my new book comes out
[Modified by TIGER UPPERCUT, 3:21 PM 7/27/2001]
Old Jul 27, 2001 | 02:31 PM
AWDSOME's Avatar
Best tips:
1. Lower front tire pressure to 21 PSI. If you want also increase the tire pressure in the rear.
2. Work on shifting faster ( alot of people lose time by shifting to slow)
3. In the beginning don't worry about a perfect reaction time of .500. The clock doesn't start ticking till you begin rolling. Instead focus on lauching the car. After you get your launches down then go for the .5XX reaction times (in other words start at the third yellow).
4. Don't trust your tachometer if it is stock. I rev mine till about an indicated 8800RPM. You will probably hit you limiter the first time you try, but it is Ok just remember where the needle was when you hit the limiter for next time and shift right before it).
5. Launches vary, but lately I have had a lot of success launching around 4.5K. Before I used to have to ride the clutch a little more or I would spin to much.
6. If you are going to drag alot invest in motor mount inserts ($30). They will stop your front end from hopping so much. It will not help your 60' time, but it will save you some very bad hopping and excessive abuse.
Good luck!
Old Jul 27, 2001 | 04:24 PM
itr0032's Avatar
14.90 stock with 2,000 miles and then 14.71with comptech exhaust and air filter
Old Jul 27, 2001 | 06:37 PM
JoshRambo's Avatar
Default Re: Your best bone-stock 1/4 times (itr0032)
i just got back from the strip and ran 15.2xx al night long. the last run was 15.199. i just can't get under it. it was only my 2nd time to the track and i shaved .3 off my othe best so i am getting better. by the next time i go i should have my headers on and maybe a VAFC if all goes as planned.
Old Jul 27, 2001 | 07:39 PM
Wildohiorice's Avatar
New User
Default Re: Your best bone-stock 1/4 times (Gravity)
Lol my best time was a 15 flat and the was my first time drag racing now i can;t seem to break 15.2 and that;s bone stock
Old Jul 27, 2001 | 08:11 PM
nEoMuGen's Avatar
Default Re: Your best bone-stock 1/4 times (Wildohiorice)
hmm......guess that's why car&driver rates our car at 15.2
Old Jul 27, 2001 | 08:24 PM
Downey's Avatar
Default Re: Your best bone-stock 1/4 times (nEoMuGen)
at Sears Point on wednesday, there was a 00 PY Type R
with, Comptech lightend flywheel, clutch, headlight ram air into stock box, test pipe, N1 exhaust, stripped interior (carpet, rear & passanger seats) and he had BFG Drag Radials on stock rims up front and 16" Spoon SW388s in the back
Ran a best of 13.8 at 100+mph. He was slipping the clutch from 6000rpm!
Old Jul 27, 2001 | 08:59 PM
RagingAngel's Avatar
Default Re: Your best bone-stock 1/4 times (Downeybear11)
I think the time is in my sig....
2.201 60ft time....
Everything was stock....full interior..minus spare/tool kit. Had the gas light come in intermittently.....
Aiming for anything in the 13s though before the end of this season...!!
Old Jul 27, 2001 | 09:02 PM
97 TYPE-R 312's Avatar
All times were done in stock form on RE010s (2550 lbs.):
14.39 @ 96.256
2.30 60ft
6.15 330 ft
9.33 1/8th
12.06 1000ft
14.49 @ 96.262
2.28 60ft
6.20 330ft
9.41 1/8th
12.15 1000ft
These times were stock as above, just with 15" M/T Slicks on 98 Accord steel wheels below:
14.01 @ 96.458
2.06 60ft
11.68 1000ft
14.03 @ 97.865
2.05 60ft
5.85 330ft
9.01 1/8th
11.72 1000ft
I nolonger drag race.
Thanks,
Victor Perri II
Old Jul 27, 2001 | 09:04 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: Your best bone-stock 1/4 times (97 TYPE-R 312)
Damn Vic...nice!
Old Jul 27, 2001 | 10:38 PM
97ITR's Avatar
14.89 @ ~93 mph
2.4 60 ft time
28 psi in crappy Dunlop W10's
full interior, 3/4 gas, removed spare tire/tools
Old Jul 28, 2001 | 06:20 AM
yakkosmurf's Avatar
Default Re: Your best bone-stock 1/4 times (97ITR)
I only went to the track once. It was after I had installed my AEM CAI and DC 4-1. I could only manage a 14.4 @ 95. I didn't feel I got a good launch, but my 60' time was a 2.212. The car weighed in at 2700 lbs with me in it. It had a full interior, fully inflated stock tires, and a 1/4 of a tank of gas. I might go back to the drag strip after I get my Icebox and JDM header with test pipe. I'm not much into drag racing. I need to learn to launch.
