For all the people who swapped in NSX calipers or plan to..
Old Jun 30, 2003 | 03:35 AM
00 FBP ItR's Avatar
Default For all the people who swapped in NSX calipers or plan to..
I'm about to do this.. but w/ legend calipers.. which are much cheaper and more effective
Legend calipers are better than NSX because the NSX uses 40/36mm pistons
and the Legend uses 42/38mm pistons.
NSX = 250-300+
Legend = 50-150
So this should be mod should be comming soon...
All i need to do is swap the calipers right? (from L->R i mean)
Legend L to my R, vise versa..
Legend Calipers, Rotors, Pads..
Any other advice? or parts needed? the caliper will be completely rebuilt as well
Old Jun 30, 2003 | 03:46 AM
Asahi's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">I'm about to do this.. but w/ legend calipers.. which are much cheaper and more effective
NSX = 250-300+
Legend = 50-150
All i need to do is swap the calipers right? (from L-&gt;R i mean)
Yes you need to swap left to right and vice versa. You don't need legend rotors but the extra mass helps with heat if you are doing tracking (Don't think they will matter at Auto-x).
I got mine for $80 shipped so they definitely can be found for a deal.
That said, I was under the impression only the secondary piston was 2 mm larger. Also, I feel I have used my calipers long enough to prove no ill effects to swapping sides but you will find those with NSX calipers claim that we are hurting ourselves by changing the leading piston (Swapping sides). Although a valid concern I think the issue has been disspelled. I have experienced no uneven wear and have had good breaking on track, auto-x and street with them.
Old Jun 30, 2003 | 03:59 AM
00 FBP ItR's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">
That said, I was under the impression only the secondary piston was 2 mm larger. Also, I feel I have used my calipers long enough to prove no ill effects to swapping sides but you will find those with NSX calipers claim that we are hurting ourselves by changing the leading piston (Swapping sides). Although a valid concern I think the issue has been disspelled. I have experienced no uneven wear and have had good breaking on track, auto-x and street with them.</TD></TR></TABLE>
Well the thingl w/ changing the leading piston... I don't think it would hurt at all, since stock calipers don't even come w/ a secondary piston at all. Even w/ the pistons swapped, if there was to be any uneven wear it would still wear more evenly than stock calipers would, So as long as its better than stock..
Well I don't track.. No spare $$ to, i was planning to go to expo 4 if it was closer to So Cali, but the location changed. I'll be @ one of the Expo's for sure..
But I do drive local mountain roads
And the legend rotors would hurt.. I might as well while i'm tearing up my brakes.
Old Jun 30, 2003 | 09:23 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">Well I don't track.. No spare $$ to, i was planning to go to expo 4 if it was closer to So Cali, but the location changed. I'll be @ one of the Expo's for sure..</TD></TR></TABLE>
Expo 4 is still on the west coast.
Old Jun 30, 2003 | 10:07 AM
Asahi's Avatar
It IS on the west coast and very close to LA. It is 1/2 the distance from LA than the distance I had to drive this year as the organizer and I have 1800 miles to drive to Expo 4 . . . 300 miles is kids play.
This will be your best opportunity for a close Expo for a long time . . .
Old Jun 30, 2003 | 10:09 AM
Flux's Avatar
How much do the Legend calipers weigh?
Old Jun 30, 2003 | 10:10 AM
Asahi's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">How much do the Legend calipers weigh?</TD></TR></TABLE>
Alot. Same as NSX and Type-R Calipers. What does a stock ITR caliper weigh?
Old Jun 30, 2003 | 10:21 AM
eviltwin's Avatar
anyone have a link where i can find the legend calipers for such a low price.
Old Jun 30, 2003 | 10:27 AM
sa04's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (eviltwin)
Try calling your local junkyards or use http://www.car-part.com
magic hat #9's Avatar
do the legend calipers require any modification to fit on an R?
what are good sources for legend calipers? junkyards?
expo4, go trey!!!
Old Jun 30, 2003 | 10:34 AM
sublimnal's Avatar
i heard you have to use washers for the calipers but what size does the washers have to be.
Old Jun 30, 2003 | 10:37 AM
Willard's Avatar
https://honda-tech.com/zerothread?id=258996
Old Jun 30, 2003 | 11:02 AM
Default Re: For all the people who swapped in NSX calipers or plan to.. (Willard)
aye, so no modification required. do they use the same pad size as oem R?
which model/year legend calipers are we looking for? gs model only? carparts.com lists a wide selection/price with gs/ls and coupe/sedan model included.
Modified by magic hat #9 at 3:14 PM 6/30/2003
Old Jun 30, 2003 | 11:07 AM
Willard's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (magic hat #9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">do they use the same pad size as oem R?</TD></TR></TABLE> yup
Old Jun 30, 2003 | 12:11 PM
baonest1's Avatar
anyone want to tell me that legend calipers will not fit on my LS??
Old Jun 30, 2003 | 12:25 PM
CW-ITR's Avatar
"which model/year legend calipers are we looking for? gs model only? carparts.com lists a wide selection/price with gs/ls and coupe/sedan model included." &lt;------Some one please reply to this. I'm having the same question. Thanks.
Old Jun 30, 2003 | 12:30 PM
Looose_R's Avatar
NSX = 250-300+
Legend = 50-150
i chose nsx calipers because they will cool faster than the legend, and they are bling bling. nsx you DONT need to swap sides and only 1small washer is needed as long as you use legend GS rotors.
Old Jun 30, 2003 | 02:24 PM
00 FBP ItR's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (b20bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20bastard &raquo;</TD></TR><TR><TD CLASS="quote">
i chose nsx calipers because they will cool faster than the legend, and they are bling bling. nsx you DONT need to swap sides and only 1small washer is needed as long as you use legend GS rotors.</TD></TR></TABLE>
how do they "cool faster"... & just b/c they are bling bling?
haha.. well alot of people here would rather have a cheaper and more effective caliper...
less than 1/2 the price and bigger pistons..
Old Jun 30, 2003 | 05:30 PM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">do the legend calipers require any modification to fit on an R?
expo4, go trey!!!</TD></TR></TABLE>
I got my Calipers from http://www.car-part.com as mentioned above. Seems like they are from a 93-94 (maybe more years) Legend Coupe.
No modification except side swapping needed (Unless you run legend rotors).
NSX Calipers do have fins for cooling but I am not convinced they are significant to do much and certainly not enough on a street car to matter.
Old Jun 30, 2003 | 05:40 PM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">I got my Calipers from http://www.car-part.com as mentioned above. Seems like they are from a 93-94 (maybe more years) Legend Coupe.</TD></TR></TABLE>
Hrm, this gets me thinking. This upgrade should be practically free for me.
So what model/year exactly? The 6-Speed Legend Coupes use different Calipers/brake pads from the Automatic models.
Old Jun 30, 2003 | 06:05 PM
Looose_R's Avatar
less than 1/2 the price and bigger pistons.. </TD></TR></TABLE>
well smarty pants they have a heatsink. lets see who is fading after 20laps
Old Jun 30, 2003 | 06:08 PM
Asahi's Avatar
well smarty pants they have a heatsink. lets see who is fading after 20laps </TD></TR></TABLE>
I didn't ever fade after 30 minutes on track with my stock calipers and it only got better with the Legend Calipers. We weigh a good bit less than an NSX . . .
len's Avatar
len
A cheap "Home Depot Sponsored" brake ducting would be much more cost effective. I just think the NSX Calipers are all bling, unless they actually provide more clamping force. But judging by the diameter of the pistons compared to the Legend Calipers, math and logic would tell you otherwise.
Old Jun 30, 2003 | 06:09 PM
len's Avatar
len
I didn't ever fade after 30 minutes on track with my stock calipers and it only got better with the Legend Calipers. We weigh a good bit less than an NSX . . . </TD></TR></TABLE>
If weight was such an issue with the calipers, could you just machine the extra material off?
Old Jun 30, 2003 | 09:52 PM
MikeSarr_GSR's Avatar
Default Re: For all the people who swapped in NSX calipers or plan to.. (len)
for non-itr owners would the fastbrakes 110x4 redrilled 5lug 11" rotors suffice using legend calipers? how much thicker are the legend rotors?
