Anyone put s2000 cluster in Dc2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuRu »</TD></TR><TR><TD CLASS="quote">Anyone? </TD></TR></TABLE>
good luck.. its been tried before, you can search the archives for more info.. the rpms and everything will work but the speedo and odometer will not work correctly or at all cause of the difference in the VSS on both cars.. the guy installed it in a 5gen civic and would be the same install in a Dc2 as well
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuRu »</TD></TR><TR><TD CLASS="quote">Humm. what if i took all the stuff from a s2000 like speedo and stuff or whatever</TD></TR></TABLE>
...do you have any idea what the hell you're doing?
Or what you're talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuRu »</TD></TR><TR><TD CLASS="quote">yes i need all the stuff that goes to the cluster and find a way to put it on a integra if possible. I want a digital Cluster. s2000 would look awesome.</TD></TR></TABLE>
I meant it in a more literal sense of...
Do you know how to do any of what you're proposing? Or any of the process that goes into doing what you're proposing? Or the exact parts and procedures needed to to what you're proposing?
IT WILL NOT WORK. The speedo sensors are different.....unless you can put an s200 tranny (never will it happen) on your teg then just give it up
