will Headers from a 96GSR fit a 90LS?
Old Jun 29, 2003 | 08:08 PM
b18polo's Avatar
Default will Headers from a 96GSR fit a 90LS?
i have a 90LS B18a with DCsport headers and i bottomed out a couple times and pinched one of pipes and one of my boys has his old(er) headers also DCsport from his 96GSR and i was wondering if anyone knew if they would fit. Thank You.
Old Jun 29, 2003 | 08:50 PM
Sohc Driver's Avatar
Default Re: will Headers from a 96GSR fit a 90LS? (b18polo)
yes, all b series headers will fit.
Khoi
Old Jun 29, 2003 | 09:03 PM
jonoknut's Avatar
Default Re: will Headers from a 96GSR fit a 90LS? (Sohc Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">yes, all b series headers will fit.
Khoi</TD></TR></TABLE>
not true. . .i cant tell you if that will bolt up, i doubt it, it may bolt to the block but the difference is where it bolts into your cat. therefore you cant just switch to a different header without modifying the exhaust.
Old Jun 29, 2003 | 10:40 PM
Default Re: will Headers from a 96GSR fit a 90LS? (jonoknut)
it should still bolt up to the cat with no problem...from experience.....my friend's integra LS has a a b16 header, and another friend with a b16a has an LS header...no modifications..
Khoi
Old Jun 29, 2003 | 11:00 PM
xteg95's Avatar
i dont think it will work, bolt patterns on gsr and ls heads are different...
Old Jun 30, 2003 | 03:13 AM
.RJ's Avatar
.RJ
Default Re: will Headers from a 96GSR fit a 90LS? (xteg01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg01 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think it will work, bolt patterns on gsr and ls heads are different...</TD></TR></TABLE>
No they're not, they're identical.
Some headers you install on a G2 you will need to cut out a section of the crossmember. For the JDM 4-1 you have to.
Old Jun 30, 2003 | 04:58 AM
xxxxspdrcr's Avatar
Default Re: will Headers from a 96GSR fit a 90LS? (.RJ)
all of the bolt patterns are the same, some headers are different lengths, but as far as bolting to the head, they are all interchangeble on the b-series.
Old Jun 30, 2003 | 07:32 AM
Default Re: will Headers from a 96GSR fit a 90LS? (xxxxspdrcr)
Old Jun 30, 2003 | 08:28 AM
xteg95's Avatar
nm then...i might have been thinking IM...(but i think these bolts might be the same too...gaskets are different though) anyway!
edit: i gotta stop posting while im half awake
Modified by xteg01 at 1:38 PM 6/30/2003
Old Jun 30, 2003 | 08:51 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg01 &raquo;</TD></TR><TR><TD CLASS="quote">nm then...i might have been thinking about the gaskets </TD></TR></TABLE>
exhaust manifold gaskets are the same too for LS/GSR/ITR
Old Jul 2, 2003 | 09:58 PM
b18polo's Avatar
i got my friends headers today and there a little bit older than mine so im keeping the top section of my headers that are not damaged and using his bottom half since my bottom is bent shut....you think it would work or will i have to get the cat choped off so it will fit?
Old Jul 3, 2003 | 05:51 AM
in my opinion it should still work..only one way to find out
Khoi
kahwhy
Jan 18, 2008 11:20 AM
94eh2
15
Sep 8, 2007 06:26 PM
honda305
Sep 24, 2006 12:04 AM
neEven
Jun 23, 2004 09:20 AM
hans stoner
Dec 1, 2003 12:06 AM
