will this cause a lean situation?
Old Jun 29, 2003 | 07:09 PM
untitled's Avatar
Default will this cause a lean situation?
gsr shortblock
b16a ported head
jdm 4-1 2.5 collector
2.25 exhaust header back. no cat.
CAI
pr3 ecu
hondata closed loop chip
would i need a fpr and a fuel rail to give this setup the extra fuel it needs? or maybe even bigger injectors? i have b16 injectors right now. also how much power would this yield?
Old Jun 29, 2003 | 07:29 PM
untitled's Avatar
Default Re: will this cause a lean situation? (88crx91integra)
hello?
Old Jun 29, 2003 | 11:11 PM
Mr.Integra's Avatar
wideband o2 + a/f readings is the only way to tell
Old Jun 30, 2003 | 05:16 PM
untitled's Avatar
Default Re: will this cause a lean situation? (Mr.Integra)
do you think i could drive on it without dangerously lean conditions?
Old Jun 30, 2003 | 06:34 PM
mmuller's Avatar
Mad Scientist
i would rather be save then sorry, get an afr and bump the psi a little
B16A CRX
Sep 7, 2007 07:34 AM
Bump
Jun 20, 2006 03:42 PM
GapxGuy
Apr 22, 2004 12:43 PM
untitled
Jun 30, 2003 05:18 PM
B19CivicHB
Oct 11, 2002 12:18 PM
