header choices
Old Jun 29, 2003 | 05:57 PM
boywonda's Avatar
Default header choices
Which is better 4-1 or 4-2-1 and please tell why below... Is there a major difference in performance? This is for a b18b
thanks
Modified by boywonda at 12:36 AM 6/30/2003
Old Jun 29, 2003 | 06:11 PM
SOHC_MShue's Avatar
Default Re: header choices (boywonda)
4-1 is usually better for top end..you may lose a little down low...while 4-2-1 is better low to midrange torque usually. What engine is this for?
Old Jun 29, 2003 | 08:20 PM
80884's Avatar
Default Re: header choices (SOHC_MShue)
I say 4-1, But I am going from my experince. Most small diss. engines have no bottom end. But thats prolly why my car can't get out of it's own way till 4,000 rpm. But above 4k it moves. 2000 civic si 1.6L (for now)
Old Jun 29, 2003 | 08:27 PM
boywonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote"> What engine is this for?</TD></TR></TABLE>
b18b
Old Jun 29, 2003 | 08:39 PM
boywonda's Avatar
47 views and only 4 votes c'mon
Old Jun 29, 2003 | 08:54 PM
ramz7887's Avatar
I went with the dc 4-1 ceramic header on my d16y8. It gave me a nice mid to high increase in hp. It also makes a cool voosh noise during wot and vtec. Also it is a lot lighter over stock.
Old Jun 29, 2003 | 09:11 PM
ap0kalypse's Avatar
i have had both 4-2-1 and 4-1, i like the 4-2-1 because of the low end power, but the 4-1 has the top end power with a little low end sacrifice. it depends on what you want to do with motor. if its mainly daily driving, i hear people prefer 4-2-1, because they can use that low end power for quick pick up speed.
i am currently using a jdm 4-1 now, i like the top end.
Old Jun 29, 2003 | 09:39 PM
Daniel's Avatar
what are your powerband plans? low-end "grunt" (if there's such a thing on hondacuras ) or high-end pull? base your decision on that. when i went back to all-motor, i wanted lots of low-end since it was becoming my daily driver again, so i went with a 4-2-1 header (lost my stock header somewhere), OEM exhaust, and an iceman intake, which is said to yield good low-end results. it's better to do that than to mix and match parts that gain power in different parts of the rev range, i think.
Old Jun 29, 2003 | 09:46 PM
GokuSSJ4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">4-1 is usually better for top end..you may lose a little down low...while 4-2-1 is better low to midrange torque usually. What engine is this for?</TD></TR></TABLE>
depends on who makes the header , i love my heade gives you also great mid - and top end power . its been compare with the jdm 4-1
Old Jun 29, 2003 | 09:49 PM
Daniel's Avatar
Default Re: header choices (Spoon1)
is that the an-r header?
Old Jun 29, 2003 | 09:55 PM
BackSideSA's Avatar
Default Re: header choices (Daniel)
i say you rock a 421 on the LS motor
i dont think the top end that you expect out of the 4-1 will be in your gearing ration like it would be for the vtec motors. but that is what I think
Old Jun 29, 2003 | 10:05 PM
kefka's Avatar
Default Re: header choices (HybridHackBatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHackBatch &raquo;</TD></TR><TR><TD CLASS="quote">i say you rock a 421 on the LS motor
i dont think the top end that you expect out of the 4-1 will be in your gearing ration like it would be for the vtec motors. but that is what I think</TD></TR></TABLE>yea, if you had vtec then go for a 4-1... but it also depends on how you are going to utalize your motor. drag or race.
Old Jun 29, 2003 | 10:40 PM
weezercrx's Avatar
I currently have a 4-2-1 RSR header on my B16A2, and it has served me very well for 2 years. Recently i've purchased a 4-1 JDM ITR header. Im still debating whether or not i should put it on. becuse i got to get the flanges modified.
Old Jun 29, 2003 | 10:47 PM
7up's Avatar
7up
Old Jun 30, 2003 | 01:12 AM
Unsung's Avatar
The only headers made that are worth your money are 2.5" collector, and not many of them are 4-2-1. For the money, JDM DC or ANR or Header-Tech are your best buys. Don't bother with a USDM 2" collector, nearly zero power gains.
Old Jun 30, 2003 | 01:48 PM
GokuSSJ4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">is that the an-r header?</TD></TR></TABLE>
Ericks racing SS header, 2.5 collector
Old Jun 30, 2003 | 03:37 PM
b18c1guy's Avatar
how do i set a pic under my name
i need to make the pix size smaller
need help
thanxs
Old Jul 1, 2003 | 06:11 PM
boywonda's Avatar
any more info before I buy... the votes and the posts dont match up... everyones voting 4-1 but posting in favor of the 4-2-1... what gives... HELP ME
Old Jul 1, 2003 | 06:32 PM
Daniel's Avatar
this would be so much easier if you just went turbo. no more worries about 4-2-1 vs. 4-1. you'll have other stuff to worry about but just not a header.
Old Jul 1, 2003 | 07:45 PM
allmtr's Avatar
most ppl i know like and use 4-1
Old Jul 1, 2003 | 08:46 PM
boywonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">this would be so much easier if you just went turbo. no more worries about 4-2-1 vs. 4-1. you'll have other stuff to worry about but just not a header. </TD></TR></TABLE>
Wish I had the money for turbo
Maybe one day
Old Jul 1, 2003 | 11:02 PM
CivicNA's Avatar
hey i voted 4-1 but i ment to vote 4-2-1 ls motor has more bottom end power to work with go with the 4-2-1 thats what i used when i had my ls motor in my hatch. it worked great. go 4-1 with a v-tec motor
Old Jul 1, 2003 | 11:07 PM
SOHC_MShue's Avatar
Default Re: header choices (CivicNA)
go 4-2-1 for the ls
Old Jul 2, 2003 | 01:48 AM
FifthGearOnline's Avatar
you allready have more torque then most honda engines.....keep the tradition going
4-2-1
Old Jul 2, 2003 | 01:55 AM
95hbMatt's Avatar
Default Re: header choices (FifthGearOnline)
i've heard good things about people running the comptech 4-2-1 on an LS motor
Steak84SS
Nov 5, 2004 03:52 PM
InTegraLS_2001
Apr 25, 2004 08:10 PM
b18bme
Apr 20, 2004 12:06 PM
civboy115
13
Feb 4, 2004 12:23 PM
LSintegra
May 5, 2003 04:33 PM
