B16A in '86 ReX HELP!
0k, im looking to put a 1ten b16a obd 1 jdm spec into an 86 crx. will the full changeover from hmotors fit no prob, will i need extra parts? any input helps, thanks,
mike
mike
obd1 will be a pain. itll probably be easier to go obd0 because i dont think there are any conversion harnesses for 84-87 civics. also if your car is carbed that will be a problem. there is a mount kit available though to mount the engine. searching helps, a few have done that swap
my cousin just actually got done doing a B16A swap into his 87 CRX SI....
first of all u will have to rewire ur car to run with OBDO ECU's (i mean the PR3, PWO, PG7 or PR4) instead of that old vacum advanced stuff....
actually hes using a PR3 as of now(borrowed), but the permanent ecu that he will use is a PM6 Zdyne'd
go ahead and email him, he can give u the details.....
tell him chaco sent u....
his email is rnspeed@hotmail.com
http://www.hasport.com <- Mount kits, Axles, wiring harness, and other odds and ehds
http://www.redpepperracing.com < few guys were did the swap... not to many...
Rewiring can be done.... http://www32.brinkster.com/tjs....html <- best ******* chart for Electronic advanced EVAR!
ODB1 can be done if you do the elec distrib rewiring... then buy a harness from here... my friend made his own for pretty much nothing...
You WILL have a run a wire for VTEC and pick up a VSS off a 88-91 civic/CRX... they swapn right in no problem....
everything for the swap was pretty easy...place racing also makes mounts for 84-87 its a lil cheaper and they do have a difference...you will need a coulple things that u can buy or make such as shift linkage, wiring harness etc. the only thing that was pretty boring was the wiring but other than that it was kool
Pworld925
Oct 14, 2008 05:58 AM
