Vehicle weight?
Edit: This is for a 95 CX Hatch
Check This:
Specifications
Type: Compact Coupe/Hatchback
Where Built: Not Available
Dimensions
Exterior
Length: 160.2 in.
Width: 66.9 in.
Height: 50.7 in.
Wheel Base: 101.3 in.
Curb Weight: 2108 lbs.
Interior
Front Head Room: 38.6 in.
Front Hip Room: 49.8 in.
Front Shoulder Room: 53.4 in.
Rear Head Room: 36.6 in.
Rear Shoulder Room: 52 in.
Rear Hip Room: 44.6 in.
Front Leg Room: 42.5 in.
Rear Leg Room: 30.5 in.
Luggage Capacity: 13.3 cu. ft.
Maximum Cargo Capacity: 23 cu. ft.
Maximum Seating: 5
Performance Data
Performance
Base Number of Cylinders: 4
Base Engine Size: 1.5 liters
Base Engine Type: Inline 4
Horsepower: 70 hp
Max Horsepower: 5000 rpm
Torque: 91 ft-lbs.
Max Torque: 2000 rpm
Drive Type: FWD
Turning Circle: 32.1 ft.
Fuel Data
Fuel
Fuel Tank Capacity: 10 gal.
EPA Mileage Estimates: (City/Highway)
Manual: 42 mpg / 46 mpg
Range in Miles: (City/Highway)
Manual: 420 mi. / 460 mi.
Edit: cleaned it up a little. this came from http://www.edmunds.com
Check This:
Specifications
Dimensions
Exterior
Length: 160.2 in.
Width: 66.9 in.
Height: 50.7 in.
Interior
Maximum Seating: 5
Performance Data
Performance
Horsepower: 70 hp
Torque: 91 ft-lbs.
Drive Type: FWD
Fuel Data
Fuel
Guest
Posts: n/a
http://www.hondaswap.com/articles/viewer.php?id=48
1992 Honda Civic Hatchback Specifications
CX hatchback: 2094lbs.
VX hatchback: 2094lbs.
DX hatchback: 2178lbs.
Si hatchback: 2326lbs
Key Differences:
*The CX and VX have a 10-gallon tank, while the DX and Si have the 11.9-gallon tank.
*Si and DX have a Rear wiper/washer
*Si and Dx have more tar for increased quietness in cabin.
*Si and Dx have side moldings and rear cargo cover standard.
*Si came with power mirrors, power sun roof.
*Si came with rear disc brakes, while DX, VX, CX came with rear drums.
*Si came with front, rear sway bars standard.
Conclusion:
Keep in mind these cars were weighed in stock trim. This means no air conditioning or radio because it was not a standard option in any vehicle. The VX and Si were the only hatchbacks to come with 2 mirrors and a tachometer as standard equipment. For wheels, the VX came with 9lb thirteen-inch alloy wheels while the CX and DX had thirteen inch steel wheels. The Si had the heaviest wheels coming with fourteen inch steel wheels with hubcaps.
Key Differences:
Conclusion:
BauleyCivic
35
Mar 5, 2013 04:56 PM
csp39
May 26, 2012 05:05 PM
cool_junk
10
Jan 17, 2009 03:52 PM
hondaturners6002
Aug 1, 2006 04:46 PM
