Will a ABS brakes work on a non-abs car....?
Old Jun 29, 2003 | 05:08 PM
Comfortable Rock's Avatar
Default Will a ABS brakes work on a non-abs car....?
I have a 92 civic dx four door and just got all new disc brakes from IAS......the fronts are from a '95 and the rears are from a '97.....but the brakes the car came off of had the abs system, but my car does not have the abs system (well i am pretty sure anyway). this does not matter or does it ?
just a litttle confused on this,
:cliff notes:
the brakes i bought have abs hook-up....
but my car does not have the abs system....
will it matter if i dont hook up the abs or not?
and will it work?
Old Jun 29, 2003 | 05:36 PM
Mohudsolo's Avatar
Default Re: Will a ABS brakes work on a non-abs car....? (Comfortable Rock)
The ABS would only work if you also have the hydraulic controller and all the electronics and wiring. There should not be any problems with using them without the ABS hooked up. You may need a proportioning valve and the master cylinder for rear discs.
boostedr
Jul 9, 2005 04:59 PM
Fraggle
Nov 2, 2003 11:03 AM
oioioi
Jan 23, 2003 02:56 PM
