Car Idling at 1500 RPM
Old Jun 29, 2003 | 04:59 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Car Idling at 1500 RPM
A Buddy of mines car is idling awfully high ...we were wondering what it could be...any help would be appreciated...
Edit: the motor is a b16a first gen
Old Jun 30, 2003 | 12:56 PM
PinchE NegRo's Avatar
Default Re: Car Idling at 1500 RPM (ciRcuit_ _ _)
help me!
Old Jun 30, 2003 | 02:12 PM
RABBIT9's Avatar
Default Re: Car Idling at 1500 RPM (EK-TUNED)
IACV would be my first choice.
TPS would be my second.
I had the same problem, and just replaced both. Everything's back to nornal now.
Old Jun 30, 2003 | 04:36 PM
quik1's Avatar
Default Re: Car Idling at 1500 RPM (RABBIT9)
Could be a vacume leak.
Old Jun 30, 2003 | 07:39 PM
Hondaaccordvtec's Avatar
Default Re: Car Idling at 1500 RPM (quik1)
Have you tried adjusting the idle screw on the throttle body?
Old Jun 30, 2003 | 09:07 PM
sslude's Avatar
Default Re: Car Idling at 1500 RPM (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried adjusting the idle screw on the throttle body?
</TD></TR></TABLE>yes yes, try that
Old Jun 30, 2003 | 09:25 PM
00blackcivicsi's Avatar
Unless some one has messed with it they don't usualy just move their self so that pob. not it.
But it will fix the idel,just not the right way.
Old Jul 1, 2003 | 10:54 PM
Default Re: (00blackcivicsi)
i tryed ****** with that little screw but my idle is still high! so i dunno wut to do..?
Old Jul 2, 2003 | 04:12 AM
EE_Chris's Avatar
Default Re: (EK-TUNED)
On Speed-Density metered systems, additional air introduced into the intake only serves to raise engine speed (rpm). You have a source of unmetered air, a.k.a vacuum leak.
Are you throwing any codes?
Old Jul 2, 2003 | 09:32 AM
Default Re: (EE_Chris)
this morning i did get a check engine light when i was warming up my car... but i turned the car off and back on again and it was gone... and wut do i do about a vacume leak...?
Old Jul 2, 2003 | 09:35 AM
i was planning on getting a skunk2 mani, would that just solve my problem...?
Old Jul 2, 2003 | 10:08 PM
i dont have a vacume leak. i checked it over and over and i dont have a vacume leak... i fucked with that little srew already but still no help... wut do i do....?
Old Jul 3, 2003 | 04:46 AM
evo's Avatar
evo
New User
I have the same problem, everytime I stop at traffic light it idle 1500rpm, when I light touch the accelerator it goes back to normal. any idea what's went wrong??
Old Jul 3, 2003 | 09:13 AM
advanracing62's Avatar
Default Re: Car Idling at 1500 RPM (evo)
check the throttle cable and the butterfly. They may be sticking, or the cable may be too tight.
Old Jul 3, 2003 | 09:45 AM
Default Re: Car Idling at 1500 RPM (advanracing62)
tryed that... any thing else i can do.....?
Old Jul 3, 2003 | 11:45 AM
double check for CEL- double check IAC
Old Jul 3, 2003 | 12:16 PM
****! now my engine is reving by it's self! it goes from 1000 rpm's to 2500 rpm's by its self while the car is runing...
Old Jul 3, 2003 | 12:18 PM
eg6h8k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TUNED &raquo;</TD></TR><TR><TD CLASS="quote">****! now my engine is reving by it's self! it goes from 1000 rpm's to 2500 rpm's by its self while the car is runing... </TD></TR></TABLE>
looks like a leak..i had this prob..solve the leak and it stills idle shitty..:/
Old Jul 3, 2003 | 12:28 PM
Default Re: Car Idling at 1500 RPM (eg6h8k)
I used to have this issue.... It was a gasket leak at the TB and plenum... spray some crap on there and see what happens. Maybe the O2 sensor also???
Old Jul 5, 2003 | 04:21 PM
quik1's Avatar
Also check your fast idle valve they often go bad.
Old Jul 6, 2003 | 09:21 PM
garagespecial
Guest
Posts: n/a
its the heat....hot weather out here does it to us.....
Toanz
Jun 23, 2008 03:57 PM
jcfreibert
10
Nov 23, 2007 10:51 AM
Kirk@SyndromeAuto
Jan 17, 2007 11:14 AM
redED9Si
Aug 21, 2005 06:58 PM
fishman
Aug 15, 2002 07:05 PM
