Timing belt pulley stuck
Old Jun 29, 2003 | 02:09 PM
Mover's Avatar
Default Timing belt pulley stuck
My timing belt pulley (#16) seems like its fused to the to the crankshaft.
The pin doesn't even slide off ! Anyone come up with a good technique to
remove this when its fused like this ?
http://www.hondaautomotivepart...ISTON
You can't even slide a screwdriver between the pulley and the oil pump.
Old Jun 29, 2003 | 02:57 PM
irev210's Avatar
Default Re: Timing belt pulley stuck (Mover)
okay, take wd-40 and spray it a little, then tap it with a hammer or rubber mallet. Then just slowly try to slide it back and forth. Sometimes they can be lil bitches, but if all else fails just start beating on it with a hammer and that will loosen it up.
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
us31wking
Aug 21, 2014 04:50 AM
99blackdc2
Jul 28, 2006 07:23 PM
Mover
Jun 29, 2003 07:03 PM
h46it
Mar 21, 2002 07:57 AM
