finished installing ground control in crx,kinda...
hey guys,i finally got my ground controls installed in my '89 crx si last night.i have them paired with agx shocks.there is only one problem.i noticed when i took it out for a spin occasionally i got this clunkng or clicking kinda sound.it didnt make it the whole time,but when it did it was very annoying.it sounded like it was coming from the front drivers side.the rears are fine though.i do have the fronts almost at the lowest possible setting.should i raise it up abit ?is there other things i can check to make sure there not the problem?thanks in advance
1.) your tire may be rubbing (unlikely in teh front though unless you are slammed)
2.) your CV could be going out- did you see excessive grease on teh passenger side axle?
actually there was a ton of grease on that side.what does that mean?if my cv is going out what do i need to do?will i have to replace the shaft and everything?will i have to fix just the passenger side or both?
well clunking noise is probably your axle...so replace your passenger side axle...or whatever one with grease coming out they are like 80$ at pep boys with lifetime warrantee
JUNKYARD_R
Feb 17, 2008 04:53 AM
