Did my buddy bend a valve???
Old Jun 29, 2003 | 09:50 AM
Ryan C's Avatar
Default Did my buddy bend a valve???
My buddy was racing a street bike in his turbo GSR integra...he was in 5th and wanted some extra power so he downshifted...and then the unthinkable, you 2nd not forth....the check engine light flash alittle but the car still drove okay....until we got to a red like the idle a rough, so rough the car shakes a little and there is a little tic to it now too...what could it be and how do we tell?
Old Jun 29, 2003 | 10:25 AM
Volcom's Avatar
Default Re: Did my buddy bend a valve??? (Ryan C)
It's toast
Old Jun 29, 2003 | 11:38 AM
Ryan C's Avatar
Default Re: Did my buddy bend a valve??? (Volcom)
geez, thanx for the info...anyone alse care to elaborate?
Old Jun 29, 2003 | 12:48 PM
irev210's Avatar
check the timing belt, at um 13k+ or whatever u were at, u coulda slipped a few teeth.
Do a compression test, that will tell you a little more.
Old Jun 29, 2003 | 06:03 PM
Ryan C's Avatar
Default Re: Did my buddy bend a valve??? (irev210)
i dont think it slipped any teeth...but the cop test is a good idea...thanks
any one else?
Old Jun 29, 2003 | 06:28 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">My buddy was racing a street bike in his turbo GSR integra...he was in 5th and wanted some extra power so he downshifted...and then the unthinkable, you 2nd not forth....the check engine light flash alittle but the car still drove okay....until we got to a red like the idle a rough, so rough the car shakes a little and there is a little tic to it now too...what could it be and how do we tell?</TD></TR></TABLE>
That sucks. That's likely to have fucked up something good. Definately do a compression and leakdown test.
list the numbers and where the hissing (if any) is coming from.
Leakdown.......
You need 95% or better. Get a 80-85% and you've slightly hurt that cylinder. Get a 40-50% and its scrap.
Compression.......
I think on a B18C1 you're looking for 270 psi, within 5-10 psi spread.
Under 135 psi, scrap.
Old Jun 29, 2003 | 08:10 PM
Ryan C's Avatar
Default Re: Did my buddy bend a valve??? (RyanCivic2000)
alrighty, here are the results....
210
152
210
210
i guess its pretty apparent that we have a problem.
the noise is that ticking noise that people always refer to as a lifter.
is it possible that the valves in that cylinder need to be adjusted or they are just bent?
Old Jun 29, 2003 | 08:12 PM
Ryan C's Avatar
oh...and is a leakdown test a DIY type process or what???
Old Jun 29, 2003 | 11:21 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">oh...and is a leakdown test a DIY type process or what???
Well if you have the results did you diy? Or did you have a shop do it? Yes if you have a tester you can do it yourself.
Oh and he may fried his rings as well.
Old Jun 30, 2003 | 07:11 AM
Ryan C's Avatar
Default Re: Did my buddy bend a valve??? (Vinceg99)
a leakdown test is the same as a comp test?
Old Jun 30, 2003 | 07:14 AM
Yougod's Avatar
Hopefuly it's "only" a bad ring.
Old Jun 30, 2003 | 09:13 AM
GSpeedR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">a leakdown test is the same as a comp test? </TD></TR></TABLE>
Nope.
Do a search for "leakdown test" and you'll find some posts on how to perform one.
Old Jun 30, 2003 | 11:38 AM
Ryan C's Avatar
Default Re: Did my buddy bend a valve??? (GSpeedR)
didnt find ****
Old Jun 30, 2003 | 08:35 PM
Volcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">geez, thanx for the info...anyone alse care to elaborate?</TD></TR></TABLE>
You asked and I replied. Sounds like bent valves to me. The rough idle kinda gives that away.
Old Jul 1, 2003 | 09:22 AM
luckypon7's Avatar
do you have a breather filter? if you see smoke and oil spitting out that would let you know your rings are damage.
Old Jul 1, 2003 | 10:21 AM
GSpeedR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">didnt find ****</TD></TR></TABLE>
28 replies for "leakdown test"...
Try a little harder next time.
Old Jul 1, 2003 | 12:07 PM
Ryan C's Avatar
thanks dick
Old Jul 1, 2003 | 03:18 PM
GSpeedR's Avatar
Wow, incompetent and unappreciative...
Old Jul 1, 2003 | 05:42 PM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">a leakdown test is the same as a comp test? </TD></TR></TABLE> i will search too
Old Jul 1, 2003 | 08:28 PM
Fkned2003's Avatar
a comp. test tells u the psi in the cyl. .Aleakdown tells u how much percent of the compressed air u put into the cyl. leaks,either past the rings ,u will hear thru the breather ,past the int valve will hear it from the manifold, or the exh. valve from the headers.
Old Jul 1, 2003 | 08:56 PM
wm5holla's Avatar
Default Re: (Fkned2003)
i think what he wanted to know was ..
1)why do me a compresstion test?
2)why do a leakdown test?
Old Jul 1, 2003 | 09:03 PM
Fkned2003's Avatar
you do a leakdown so u know where the cyl. is leaking from,comp test wont tell u that
Old Jul 1, 2003 | 09:04 PM
Ryan C's Avatar
Default Re: (wm5holla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">a comp. test tells u the psi in the cyl. .Aleakdown tells u how much percent of the compressed air u put into the cyl. leaks,either past the rings ,u will hear thru the breather ,past the int valve will hear it from the manifold, or the exh. valve from the headers.2)why do a leakdown test?</TD></TR></TABLE>
thats exactly what i wanted to know thank you
P.s. i am in no way unapreciative ect ect blah blah...i just prefer answers instead of the "do a search" relpy
Kusai.Nihonjin.Desu
Honda Motorcycles
13
Jun 23, 2008 06:19 PM
aznryd3r
Honda Motorcycles
11
Apr 6, 2006 09:11 AM
eg6T
Honda Motorcycles
48
Mar 1, 2006 01:24 PM
GQ 05YellowEVO8
Honda Motorcycles
20
Nov 28, 2005 10:25 AM
W.O.P.
Honda Motorcycles
30
Jun 24, 2005 11:53 PM
