Idle with AC kicking on?
Old Jun 28, 2003 | 07:26 PM
95 integra's Avatar
Default Idle with AC kicking on?
My idle jumps down to about 600 rpms whenever the AC kicks on, I checked the A26 wire for 5V which is suppose to tell the ECU when its about to kick on and its suppose to compensate and raise the rpms. Has anybody else had this problem? Is that normal or do I need to try another ECU?
Old Jun 28, 2003 | 07:28 PM
p1ccoloz's Avatar
Default Re: Idle with AC kicking on? (95 integra)
mine does that too, i take it as normal....
Old Jun 29, 2003 | 07:16 AM
95 integra's Avatar
Default Re: Idle with AC kicking on? (p1ccoloz)
Thanks, but I really dont think its normal. Sometimes it drops down around 600 and gets really rough...which just doesnt seem right to me.
Old Jun 29, 2003 | 07:21 AM
Hairy Gorilla's Avatar
When I turn mine on, sometimes it will drop down that low, but instantly raise back up to about 7 or 800rpm's.
Old Jun 29, 2003 | 07:56 AM
Brian_TII's Avatar
You may want to try cleaning your idle air control valve.
Old Jun 29, 2003 | 08:17 AM
95 integra's Avatar
Default Re: Idle with AC kicking on? (Brian_TII)
Thanks, Ive been thinking the IAC might be the problem, but it still works fine when I crank the car(ie it idles to 1500 then steadily goes down as it warms up) which is controlled by the IAC, thus its atleast working.
Bhi Rds
May 8, 2016 06:19 PM
susy76
May 26, 2013 02:38 PM
AnthrPludedriver
May 22, 2007 07:40 AM
ek9mugen
23
Apr 10, 2004 10:32 PM
FLCivic
Sep 19, 2002 11:54 AM
