Block girdle.
Old Jun 28, 2003 | 11:23 AM
-Racer X-
Guest
Posts: n/a
Default Block girdle.
ok, ive heard 2 stories about em, people say to run one if you are gonna be revving high, and ive also heard it isnt really neccassary...anyone got some more info besides that it strenthens the block and what would happen if you had a fully built motor and you dont run one?
Old Jun 28, 2003 | 08:31 PM
one.EG6's Avatar
Default Re: Block girdle. (-Racer X-)
up.
Old Jun 28, 2003 | 09:33 PM
eg_type_r93's Avatar
the block girdle counter acts crank shaft harmonics at high rpms, is that clear enough for ya
in other words take what ever helps or you'll be sorry
Old Jun 30, 2003 | 10:39 PM
1titesol's Avatar
Default Re: (eg_type_r93)
I agree with eg_type_r93. If it's fully built , i'd make sure everything was safe. Honda did it on gsr, type r, and others. Rather be safe than sorry. You might have to change windage tray, oil pick up, and oil pan.(not sure)
Old Jul 1, 2003 | 05:08 AM
sleeper4dr's Avatar
Default Re: (1titesol)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1titesol &raquo;</TD></TR><TR><TD CLASS="quote">I agree with eg_type_r93. If it's fully built , i'd make sure everything was safe. Honda did it on gsr, type r, and others. Rather be safe than sorry.</TD></TR></TABLE>
to run a girdle in an LS/B20 bottom end you will need to get a GSR windage tray and oil pickup. i use a GSR oil pan too but i think the stock LS pan might work.
my understanding is that the girdle really isnt doing much unless you are spinning to 8500rpm+. but if you are building the engine anyway, why not add the girdle so that you can more safely rev to 9000rpm+ (valvetrain allowing) if you should go with BIG cams.
Old Jul 1, 2003 | 09:16 AM
-Racer X-
Guest
Posts: n/a
Default Re: (sleeper4dr)
ya, im gonna be running JUN3's and also be revving to somewhere around 9500...so heh
Old Jul 1, 2003 | 09:51 AM
mmuller's Avatar
Mad Scientist
Default Re: (-Racer X-)
make sure you get dowel pins put in there.
Old Jul 1, 2003 | 12:23 PM
sleeper4dr's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get dowel pins put in there.</TD></TR></TABLE>
definitely.
Old Jul 1, 2003 | 08:35 PM
dfoxengr's Avatar
make sure you also dont want a bigger stroke...
Old Jul 1, 2003 | 09:45 PM
granada_sun's Avatar
whats the difference between gsr pick-up/windage and b16 "/" ?
Old Jul 2, 2003 | 09:21 AM
mmuller's Avatar
Mad Scientist
Default Re: (granada_sun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference between gsr pick-up/windage and b16 "/" ?</TD></TR></TABLE>
need to use a gsr one since the b16 dont have a griddle
Old Jul 2, 2003 | 09:24 AM
need to use a gsr one since the b16 dont have a griddle</TD></TR></TABLE>
does anyone have a pic of girdle? I must be thinking of windage tray (?) that covers the oil pick up when the oil pan is removed....
Old Jul 2, 2003 | 09:58 AM
Lip's Avatar
Lip
http://www.z10eng.com/index2.cfm some pics here
Old Jul 2, 2003 | 10:54 AM
coo.....
so i take it it bolts right onto the bearing caps or....?
b18bc3po
17
Oct 8, 2009 07:28 AM
jdmjaser
Northwest (Sales)
Apr 7, 2006 03:20 AM
1quickhatch
46
Feb 1, 2005 11:40 PM
vtec.dc2
Sep 12, 2003 10:50 AM
Dgr8wun
Jun 10, 2003 06:26 AM
