jdm front end question?
if i got just the bumper, head lights and hood. could i use my stock fenders and bumper valance?????? ( i think thats what its called the little piece between the hood and the bumper)
you need the SiR filler part (between the lights and bumper) stck fenders will work but they might not meet up perfect. If you dont tell they wont notice
check out nitekids.com for pics with JDM bumper only.
No you do not need the JDM "radiator support" piece.
I have a JDm front end on my CRX. I used the US radiator support and it fitted just fine. I helped a friend recently install his JDm front end. He had the JDm radiator support and I had to modify it exactly the same as I had to modify the US one. So if you can't get the Jdm radiator support, KNOW FOR A fACT that the US one will work exactly the same.
And no you do not need the Jdm fenders to make the front end work.
on my car i tested the hood and the latch was about an inch or so forward from the hole. when i got the JDM rad suport it fit perfect.
Sorry, I don't buy it.
I just did the JDM front end thing. Using ALL the JDM parts, and still the hood did not close AND latched like the stock one.
The difference is not in the radiator support, but on the chassy it self.
wait a couple weeks then check out nitekids.com pics and everything you need to know on changing a CDM DX to a JDM SiR minus the RHD.
i know for a fact they are different i just personaly did one on my own car and pics to prove it. just look. but maybe im wrong maybe i got lucky?
i drove mine with ONLY the bumper
but to have the lights and the bumper hood and everything you need the rad sup. and the peice between the headlights and the bumper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spaceballs the lunch box »</TD></TR><TR><TD CLASS="quote">Sorry, I don't buy it.
The difference is not in the radiator support, but on the chassy it self.</TD></TR></TABLE>ur wrong on that one when i got my front clip i un bolted the rad support myself and bolted to the us civic front end and after al that bolted the hood on....and it lined up fine.....the rad support is different and sits out further...looks different also....the bumper mounts on the jdm sir is different also sits out further making the bumper stick out further....if u get the whole front clip with them everything will line up with the fenders if not the fenders and bumper wont line up in the fender well correctly and ull need spacers to make the bumper stick out furth
try to get a radiator support off of a ef1 chassis from the importer where you get the front end from. it is the one without the grill. These fit perfectly on US cars for the Si-r conversion. Ef1's or style S-II have a sohc , with Si-r look. No modifying of the hood latch at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by himynameis »</TD></TR><TR><TD CLASS="quote">so are you saying you can just use the bumper, put it on and it should all fit up fine? using US head lights,hood,and fenders?</TD></TR></TABLE>
Yes. That works.
Yes. That works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. skelly »</TD></TR><TR><TD CLASS="quote">
Yes. That works.</TD></TR></TABLE>
No, sorry.
the JDM bumper does not fit just fine with the US hedlights and hood.
You cannot mix and match hood lights and bumper.
they are either all JDM or all USDM.
the fenders are optional, the US ones will work with the JDm front end.
No, sorry.
pic with just bumper....... http://www.nitekids.com
photos section. all i had to do was get the longer bolts for the passenger side if i recall right. drove like that for a season
ill have pics soon of my freshly painted Sir conv DX :D i missed her
No, sorry.
the fenders are optional, the US ones will work with the JDm front end.</TD></TR></TABLE> if ur talking about the crx ur correct but the hatch u can use just the bumper the filler is a seperate part on the hatch not like the crx
No, sorry.
I just wanted to be clear, I could use just the hood, bumper, and headlights... and I wouldn't need the radiator support?
I have a CRX, and it seemed to work for Spaceballs... but it didn't work for nitekids, but he had his HB pictured. Maybe it's different between the 2?
I just wanted to know if this is in fact true cause I would like to save a few bucks if possible.
OK, I think a clarification is in order here.
I am speaking about the CRX.
On the CRX, you cannot just use the JDM bumper and keep the US hood and lights. They don't line up.
On the CRX, you can get away with using the US radiator support. I have installed the JDM radiator support and it still needed to be modified to latch the hood properly, just like I had to modify the US one.
So, for the CRX you really need the complete swap, (hood, bumper and headlights)and the fenders and radiator support are optional.
Can someone fill in for the hatch?
Here is a pic of the US rad support and JDM front end. no washers here.
B16Anees
Aug 21, 2003 02:01 PM
