blow by & low compression
Old Jun 28, 2003 | 10:38 AM
ritm's Avatar
Default blow by & low compression
i'm getting what i think is blow by because there is oil residue in the intake pipe where the hose that connects to the valve cover is located. and i have low compression in one of my cylinders. 3 of them are 235 and one is 205. did the rings not seat right on one of the pistons and is now blowing oil out of the valve cover? the motor was rebuilt about 12k ago. thanks in advance
Old Jun 28, 2003 | 11:50 AM
eg6ajk's Avatar
Default Re: blow by & low compression (ritm)
how do the piston tops look compared to the lower compression one. any unual oil or fuel residue or more then normal as far as carbon.
btw. 30psi is still within H/A service limit, i wouldn't worry too much about it and just check on it once in a while
Old Jun 28, 2003 | 12:40 PM
Fkned2003's Avatar
do a leak-down check. if the air comes out the int or exh manifolds its the valves. if it comes out the valve covers like u said u thought it did than its the rings.
Old Jul 13, 2003 | 01:55 AM
EG6owner-T's Avatar
Default Re: (Fkned2003)
i think i got the same problem...
so how much do the leak down test cost at shops these days?
nemesis25
Jan 12, 2015 04:17 PM
usdmblackcivic
Sep 4, 2010 11:56 PM
sirt_eg
Jun 16, 2009 01:25 PM
iBrandon
Jul 31, 2006 08:03 AM
