bad fuel economy
Old Jun 28, 2003 | 09:40 AM
redciviclx14's Avatar
Default bad fuel economy
i just changed my spark plugs. i had bosch platinum 2 but 10k miles later i had ignition problems. i found it to be that the spark plugs were all shot the tips were gone and had black **** all around it. so i changed them with ngk platinum 4's and the problem was solved. but then a new problem came with fuel economy. before i was getting 320 miles + to the tank and now i get like 250-280. i have a 93 lx 1.5 liter and it gets killer gas mileage but now it sucks. jw wondering if anyone could help with my problem. thanks tj
Old Jun 28, 2003 | 12:09 PM
eg6ajk's Avatar
Default Re: bad fuel economy (redciviclx14)
take the platiniums out and slap in a set of copper NGKs or Densos or other properly gapped name brand plugs. platinum plugs were designed to last not to create the best perfromance. i would also check out the rest of the fuel and ignition system.
change the fuel filter, rotor/cap/plug wires if they haven't been serviced in the past 25k+ miles.
Old Jun 28, 2003 | 08:01 PM
2chron4u's Avatar
Default Re: bad fuel economy (eg6ajk)
low tire pressure will murder your MPG
dwm2563
Honda CR-V & Element
Oct 23, 2014 12:00 PM
ld1985
Nov 18, 2009 12:10 PM
paulthebarbarian
Feb 11, 2005 08:48 PM
paulthebarbarian
Feb 9, 2005 09:06 PM
intek_gsr
May 17, 2003 01:38 AM
