**HELP** ASAP brake line nut stripped
Old Jun 27, 2003 | 11:19 PM
all stock's Avatar
Default **HELP** ASAP brake line nut stripped
ok folks, happened right now and I need help.
converting my rear drum to disc, i stripped the nut that i supposed to remove from the brake hardlines to put on the rear disc brake lines. WHAT CAN I USE TO REMOVE IT?? I have extra bolts, but I'm guessing i would have to cut and reflare the lines somehow...
anyone want to give me some insight?? I'm going to sears tomorrow to pick up a flare nut wrench and robogrip pliers and hope that will do it.
Old Jun 28, 2003 | 04:52 AM
wHOAlly's Avatar
Default Re: **HELP** ASAP brake line nut stripped (all stock)
vicegrips, shoulda used a flare wrench to start with
Old Jun 28, 2003 | 09:00 AM
gezer's Avatar
Default Re: **HELP** ASAP brake line nut stripped (Sp00n'd Supra)
CUT TAHT biatch off!! i hat when that happens!!! hope u get taht thing off!
sorry couldnt help all i can think of is drill it if worst comes to worst!
Old Jun 28, 2003 | 09:47 AM
all stock's Avatar
Default Re: **HELP** ASAP brake line nut stripped (gezer)
anyone else? i'm about to goto sears right now to get a flare wrench.
Old Jun 28, 2003 | 10:14 AM
all stock's Avatar
anyone got a flare nut wrench in the so cal area or wants to help me remove a stripped nut from the brake line? let me know please.
Old Jun 28, 2003 | 10:16 AM
andrew dc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n'd Supra &raquo;</TD></TR><TR><TD CLASS="quote">vicegrips, shoulda used a flare wrench to start with</TD></TR></TABLE>
vice grips!!!!
make sure you get a thick flarenut wrench....
Old Jun 28, 2003 | 10:18 AM
ERA's Avatar
ERA
You said you got another nut, right? Drill that **** out if it's really that bad... or go ghetto and find the biggest vicegrips in Socal and back that peice out!! Good Luck
Old Jun 28, 2003 | 10:30 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: **HELP** ASAP brake line nut stripped (delslo26)
like everyone else said vice grips...maybe robo grip
Old Jun 28, 2003 | 04:19 PM
all stock's Avatar
Default Re: **HELP** ASAP brake line nut stripped (ciRcuit_ _ _)
i used vice grips....
it grabs like a baby to a mother's nipple.
darthvaderglen
Suspension & Brakes
Jun 9, 2018 02:47 PM
Rene1123
May 28, 2011 04:26 PM
Championship
Jul 17, 2007 10:52 AM
Buffalo
Nov 1, 2006 06:46 AM
neilff
Nov 13, 2003 02:31 PM
