Anyone with a b20 non vtec motor in a hatch
Anyone with a non vtec b20 in a eg, if so please advise. Pics
please...1/4 mile times, parts needed to do swap, info to
help with swap ( i.e. wiring of extra sensors that my cx
doesn't have) and what tranny are you using..? please help,
need info any info would be greatly appreciated...thank you
circuit, i'm sorry but that link is so whack. It goes to a topic exactly the same as this one except its about a crx and not an eg. One guy says do a search and one guy says what he ran. If everyone says do a search, you search and you end up with more posts where people only reply "do a search", its a viscious cycle.
try these:
https://honda-tech.com/zerothread?id=238516
https://honda-tech.com/zerothread?id=189321
-johnny
try these:
-johnny
Guest
Posts: n/a
i have b20b in my hatch with 2000 si trans.. never time it. i had a b16 before also.. did not like it as much as b20. say going on the freeway with a b16 u have to wait for v-tec all the time to pick up speed..b20 picks up fast. i have to bitch shift all the time... cause the torque..just feels scary when i'm at 80mph and rpm at 4600 or so in fifth gear.. but if u go with ls trans shouldent have a prob..si trans pick up faster though in low end
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN »</TD></TR><TR><TD CLASS="quote">JDM4LIFE, did you do the swap yourself? what parts were needed? ecu? harness? and what axles did you use? thank you for your reply</TD></TR></TABLE>
any b series tranny
any 94-2001 integra axles
ls harness, or modified civic harness.
p75 (ls ecu) or a chipped dx ecu.
basically any b16 or gsr motor parts is interchangeable.
any b series tranny
im installing my 98 jdm b20b next week.i have a 2000 gsr trannny,axles,shift linkage,motor mounts,clutch,type r flywheel,94 ls intake mani,p75,and im using my stock wire harness.i cant wait!!!!
Guest
Posts: n/a
i have a 98 jdm b20 in my 93 cx hatch with a 99 si tranny..soon to be type r...i ran a 15.2 on 17in wheels...big time traction problem and full interior...that's also completely stock motor, no i/h/e.
if you want a list of everything i used pm me
How do you guys hook up on the launch with your engines. especially with the lighter cars. Feather the clutch like crazy or are you running slicks?
I only managed a best of 16.48 with my b20 teg (only 2500lbs) thanks to spinning through the entire first gear. I couldn't even roll off idle without wheel hopping from 4k on. I was only getting 83mph traps tho, so i could have used some boltons haha (and some wider tires).
d
d
motore
Aug 19, 2003 05:25 PM
