Anyone with a b20 non vtec motor in a hatch
Anyone with a non vtec b20 in a eg, if so please advise. Pics
please...1/4 mile times, parts needed to do swap, info to
help with swap ( i.e. wiring of extra sensors that my cx
doesn't have) and what tranny are you using..? please help,
need info any info would be greatly appreciated...thank you
jus f0 dekarayshunZ
Re: Anyone with a b20 non vtec motor in a hatch (4DRPIMPIN)
I have a JDM B20B non-vtec in my 92 vx hatch.....full interior and stock 13 inch vx wheels...did a 14.5 easy......it is mated up to a 94-95 LS tranny too
Re: Anyone with a b20 non vtec motor in a hatch (jdm4life)
circuit, i'm sorry but that link is so whack. It goes to a topic exactly the same as this one except its about a crx and not an eg. One guy says do a search and one guy says what he ran. If everyone says do a search, you search and you end up with more posts where people only reply "do a search", its a viscious cycle.
try these:
https://honda-tech.com/zerothread?id=238516
https://honda-tech.com/zerothread?id=189321
-johnny
try these:
-johnny
Guest
Posts: n/a
Re: (4DRPIMPIN)
i have b20b in my hatch with 2000 si trans.. never time it. i had a b16 before also.. did not like it as much as b20. say going on the freeway with a b16 u have to wait for v-tec all the time to pick up speed..b20 picks up fast. i have to bitch shift all the time... cause the torque..just feels scary when i'm at 80mph and rpm at 4600 or so in fifth gear.. but if u go with ls trans shouldent have a prob..si trans pick up faster though in low end
Re: (4DRPIMPIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN »</TD></TR><TR><TD CLASS="quote">JDM4LIFE, did you do the swap yourself? what parts were needed? ecu? harness? and what axles did you use? thank you for your reply</TD></TR></TABLE>
any b series tranny
any 94-2001 integra axles
ls harness, or modified civic harness.
p75 (ls ecu) or a chipped dx ecu.
basically any b16 or gsr motor parts is interchangeable.
any b series tranny
Re: (djhatch)
im installing my 98 jdm b20b next week.i have a 2000 gsr trannny,axles,shift linkage,motor mounts,clutch,type r flywheel,94 ls intake mani,p75,and im using my stock wire harness.i cant wait!!!!
Guest
Posts: n/a
Re: (Bigjon)
i have a 98 jdm b20 in my 93 cx hatch with a 99 si tranny..soon to be type r...i ran a 15.2 on 17in wheels...big time traction problem and full interior...that's also completely stock motor, no i/h/e.
if you want a list of everything i used pm me
Re: Anyone with a b20 non vtec motor in a hatch (93EH6)
How do you guys hook up on the launch with your engines. especially with the lighter cars. Feather the clutch like crazy or are you running slicks?
I only managed a best of 16.48 with my b20 teg (only 2500lbs) thanks to spinning through the entire first gear. I couldn't even roll off idle without wheel hopping from 4k on. I was only getting 83mph traps tho, so i could have used some boltons haha (and some wider tires).
d
d
motore
08-19-2003 05:25 PM
