Made my own.. DIY MC Brace... anyone interested...
This will be a photo post... if you're interested.. PM me.. it retains all stock wiring mounting points.. etc..
brakes are noticably stiffer
Team HD Strikes again...
HD... HomeDepot..
Not fully mounted in pics...
I used some of this for a more stealth install... pics will be up tomorrow w/ everything fully mounted.
Let me know what you think guys..
HD... HomeDepot..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">nice, how are you attaching the brace to the shock tower area?
pics of that please...</TD></TR></TABLE>
My exact question.
My exact question.
Now if you were to make it out of 3/16" plate steel and weld about 4 triangular supports like this:
And then use large bolts to throughbolt it through the shock tower, then you might have something.
i dont know how strong of a piece that mc brace needs to be without bending from the pressure...
but i will tell you that those hinges hes using are quite strong. (strong enough i had a very hard time bending them even with a clamp) they sell them at home depot for 3-4 dollars a piece, and i think they are made of some zinc/steel compound.
Just so you know,
If you do this:
http://www.hogens.com/car/defa...e.php
It also utilizes stock mounting points
If you do this:
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">
lol... i like mine better
unpainted
painted
notice how i cut round pieces out of strap steel and welded them onto the bolthead? i don't like my m/c putting all that force onto a small area. but that's just me. also, i took the tab off the wiring harness, and tacked it on there. talk about stealth, damn, i don't even know it's there. blueR and davidnyc, i did this a long time ago, and you never showed interest. humpfff...
unpainted
painted
nice piece, i would just put a larger contact on the allen bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney »</TD></TR><TR><TD CLASS="quote">nice piece, i would just put a larger contact on the allen bolt.
yeah, i'm working that part now. i've ran 3 days at VIR full and checked it after words and saw no damage or ware to the MC housing it's self, but i still want more contact than just the bolt point.
</TD></TR></TABLE>yeah, i'm working that part now. i've ran 3 days at VIR full and checked it after words and saw no damage or ware to the MC housing it's self, but i still want more contact than just the bolt point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR764 »</TD></TR><TR><TD CLASS="quote">again, here's mine
Why would you put that crap on your car when you could be using lumber brackets from home depot???
damn all you guys with welders...!!
gotta make some new friends!! Time to revamp the MCB again.....I'm somewhat inspired....
To All that made there own MC brace i give you all alot of credit for doing your own stuff.
But ill just stick with some company that makes them all day and know where to put the brace.. I think all the companys that make MC braces did alot more testing then all of you..
So ill just stick with my nice and pretty blue Cusco MC brace..
-Ross
-Ross
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotrb18c1 »</TD></TR><TR><TD CLASS="quote">I think all the companys that make MC braces did alot more testing then all of you..
umm, ok. i will put my $3 brace up against the cusco anyday. not to mention you have to modiufy the cusco to get to to work our left hand drive cars anyway... my bet is you like the sparco seat brackets too, right? after all, sparco must make better brackets then joe backyard fabricator right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney »</TD></TR><TR><TD CLASS="quote">umm, ok. i will put my $3 brace up against the cusco anyday. </TD></TR></TABLE>
same here, but technically mine cost nothing cause i used left over stock from work
gotta love having having a machine shop and material at your disposal.
umm, ok. i will put my $3 brace up against the cusco anyday. not to mention you have to modiufy the cusco to get to to work our left hand drive cars anyway... my bet is you like the sparco seat brackets too, right? after all, sparco must make better brackets then joe backyard fabricator right?</TD></TR></TABLE>
to talk about the seat bracket.. we made a set of those today too.. along w/ the mc brace...
those other MC braces look good.. but i have no access to a welder, so i can't do much better than it is..
but this MC brace holds up good enough for me.. compared to cusc0 = 80 bux?
if its starts to flex.. then o well.. i'll tighten the bolt some more...
can't ask for much if its 5 bux.. all i know is that my brake pedal is stiffer.
[QUOTE=rodney]
not to mention you have to modiufy the cusco to get to to work our left hand drive cars anyway[QUOTE]
OH You mean Modify, No I didn't have to modify my Cusco MC brace..It's in a 92 civic hatch..So I didn't have to modify anyways..
But Good try..
-Ross
But Good try..
-Ross
You gus have motivated me!
I'll be going to my local HD to make one of my own!
Can anyone tell me what size bolts I'll need? Thanks!!
The HD versions looks like it will work, but I think some of the other custom designs are probably more effective.
Personally, I'm waiting a little while longer for the IPS version...
