people with hydro tranny....how does your pedal feels...
I just change my clutch and flywheel and it's a lot softer than before. It feels like cable tranny but a lot softer. Is this normal and just want to know how other pedal feels like. thanks...
When I bought my motor the stcok clutch was slippping and it was pretty soft. I replaced it with an Exedy ordganic disc and pressure plate and a resurfaced B16 flywheel and it feels a lot stiffer now.
really? i just change my stock clutch to the exedy clutch and act flywheel and it feel really soft. Do you think that's a good thing?
I'm also curious how it feels, does your pedal have almost a foot of travel? I'd figure since it was hydro it could use a large booster or whatnot and only have to move the pedal a few inches.
sorry dont have any pics, and dont really know how to explain it. it's like the tranny cable hook up to the hydro tranny. almost like what you said, custom cable line from the hydro tranny.
like i said, the padel was hard before i change my clutch and flywheel. what could it be? or should i just leave it because it should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_89Civic »</TD></TR><TR><TD CLASS="quote"> it's like the tranny cable hook up to the hydro tranny. almost like what you said, custom cable line from the hydro tranny.</TD></TR></TABLE>
So are you using a clutch pedal from a hydro car like a 94+ Integra or are you using the EF pedal and cable with an arm mechanism on the hydraulic transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mackymcg »</TD></TR><TR><TD CLASS="quote">
So are you using a clutch pedal from a hydro car like a 94+ Integra or are you using the EF pedal and cable with an arm mechanism on the hydraulic transmission?</TD></TR></TABLE>
no me not using a clutch pedal from a hydro car. I'm using the EF pedal with an adapter bracket on to the hydro tranny. Therefore i dont think my pedal should be so shoft. shoft as in shofter then gas pedal.
hatchet_honda
Mar 2, 2010 12:20 PM
Goldfingiz
May 19, 2003 08:18 AM
89 CRX SI
Sep 25, 2002 07:04 AM
on me. I didn't see the part about hydro.
