b18b vacum line routing in EF
Old Jun 27, 2003 | 04:15 PM
Audipwr1's Avatar
Default b18b vacum line routing in EF
I need someone to tell me where they all go, they arent hooked up rigtht now and im getting a code 13 please help
Old Jun 28, 2003 | 03:25 AM
Audipwr1's Avatar
Default Re: b18b vacum line routing in EF (Audipwr1)
hello
Old Jun 28, 2003 | 08:00 AM
Audipwr1's Avatar
noone owns a b18b in an ef eh
Old Jun 28, 2003 | 08:45 AM
Blaze45's Avatar
Brrraaaap!
Yeah I know how you feel, I asked a question about a shiftlinkage and didnt get any replys. Heres what I did w/ my B20. I got a vac. T and fitted up the lines to it that didnt have a home, then ran 1 line to the IM, and I ran a line from the FPR to the IM. Sorry if that didnt help you much, thought I'd try.
Blaze
Old Jul 1, 2003 | 05:01 AM
Audipwr1's Avatar
Default Re: b18b vacum line routing in EF (Blaze45)
upo for pic
Old Jul 1, 2003 | 04:22 PM
NCchris's Avatar
The purge selenoid is mounted to the back corner of the intake plenum. Run a hose from there to the small nipple on the charcoal cannister. The other end of this selenoid goes to a small nipple on the back of the intake plenum just under the selenoid. The larger braided hose from the charcoal cannister goes to the top of the throttlebody. The 5/8 or so nipple on the valve-cover goes to the intake tube just before the throrrlebody. The large nipple on the back of the intake goes to brake booster and my pcv was already hooked up. The map sensor is on the throttlebody so you can remove and discard the firewall mounted map sensor and purge selenoid.
HTH
chris
Old Jul 7, 2003 | 06:38 AM
Audipwr1's Avatar
Default Re: b18b vacum line routing in EF (NCchris)
where is the firewall mounted map sensor?
is that the weird looking thing with 3 hoses coming out of it?
Old Jul 7, 2003 | 08:59 AM
Blaze45's Avatar
Brrraaaap!
Dttio, where is the firewall mounted MAP? not that it matters to me, I just extened my MAP sensor wires and ran it to the MAP ontop of the TB> I know where the plug is, I dont know where the old sensor was/is?
Blaze
Old Jul 8, 2003 | 11:16 AM
Audipwr1's Avatar
figured it out
the thing on the firewall with the 3 wire sensor and the 2 wire sensor is the old purge and map sensor
bypass that badboy
code 13 is gone for me now
Neekstar
Nov 5, 2008 06:21 PM
EFb18b
Jul 31, 2006 12:39 PM
nwisehart
Apr 22, 2003 10:18 AM
