does your CRX hatch rattle?
Old Jun 27, 2003 | 03:42 PM
RicedREX's Avatar
Default does your CRX hatch rattle?
is it just mine or does most poeple hatch rattle a whole lot? I mean every bump is a noisy *** time...is there anything else than the rubber seal in the hatch that I can change to help this noise out?
Old Jun 27, 2003 | 07:16 PM
etp72's Avatar
I was actually just going to post the same thing, but i figured i would be a good doobie and do a search... for "hatch rattle" and this was all i came up with. I'm new here and new with a CRX but i know hatch rattle is a problem in these so im sure its been covered before...but where? LOL
Old Jun 27, 2003 | 07:39 PM
H.crx-si
Guest
Posts: n/a
Open your hatch and look on the edge of it their should be 2 peices of screwed on rubber one on each side of the hatch. You can loosen that or screw it in further if you loosen it, that should stop the rattle cause it makes your hatch sit tighter against the shell of the car goodluck. Also wrap your hatch latch in hockey tape and it will close tighter.
Old Jun 27, 2003 | 07:46 PM
dankbudz11357's Avatar
Default Re: (H.crx-si)
my 300zx did that, well at least the hood did that. bought new rubber screw things and that solved it. thought this kind of relates.
Old Jun 27, 2003 | 08:52 PM
I8ayellowcrayon's Avatar
Hey, at least you don't live on a dirt road.... (or at least I don't think you do). Man that freakin car. The struts rattle and bump and the hatch rattles. AHHH. I only go about 15 down my road. I bottom out about 4 times on average.... You should feel lucky.
Old Jun 27, 2003 | 10:49 PM
Vinceg99's Avatar
Default Re: (I8ayellowcrayon)
Yeah you can try screwing the rubber things on each end of the hatch out to tighten everything up that helped me out for awhile next thing I am going to do is the black tape around the loop that latches it shut.
Old Jun 27, 2003 | 11:09 PM
SIRX's Avatar
Default Re: (Vinceg99)
My hatch only rattles when I hit hard bumps. You can adjust it but I've been to lazy to do mine
Old Jun 28, 2003 | 06:47 AM
rjardy's Avatar
Default Re: (SIRX)
my car is a rattle, freaking polyurethane mounts!
Rob
Old Jun 28, 2003 | 07:03 AM
insomniac791's Avatar
on my crx I tried everything I unscrewed the little rubber screws and it still ratteled. So the only thing that worked was take and the U hook for the latch I unscrewed it and took out the shim under it and it solved the problem.
hope that helps
Later
Matt
Old Jun 28, 2003 | 09:50 AM
Rywire's Avatar
Default Re: (insomniac791)
Putting electrical tape on the "U" latch worked for me. Ryan
Old Jun 28, 2003 | 01:32 PM
OreoEF8's Avatar
Default Re: (droppedcrxsi)
I put a pair of old socks inside the hatch on each side where the little rubber grommets are, and it silenced that bitch try it
Old Jul 4, 2003 | 12:35 PM
RicedREX's Avatar
thanks for thre advice, man thats alotta ghetto-tech but hopefully it helps.
Old Jul 4, 2003 | 01:16 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 &raquo;</TD></TR><TR><TD CLASS="quote">on my crx I tried everything I unscrewed the little rubber screws and it still ratteled. So the only thing that worked was take and the U hook for the latch I unscrewed it and took out the shim under it and it solved the problem.
hope that helps
Later
Matt</TD></TR></TABLE>
I agree with insomniac, there is a brass shim under the "U" lock plate
just remove it, and adjust the "U" again, and no more rattles!!
PS: You'll need at least a #3 phillips head to do it. You'll strip it, if you
try it with a #2.
Old Jul 4, 2003 | 01:30 PM
raene's Avatar
I thought I was the only ghetto **** who put black tape on the hatch latch... hahahahahah... works like a charm but you have to replace it now and then
You might want to check if your rear shocks are blown... noisy shocks make an errrch sound when they compress/rebound I believe I'll be replacing mine soon with some cheapo brand, just to quiet things down!
ampm
May 3, 2007 05:03 PM
0gravity
Dec 13, 2006 03:55 PM
theemaddhatterr
14
Jun 6, 2004 03:33 PM
TRE_
Apr 15, 2003 03:54 PM
GeeSeeR
Aug 5, 2001 11:14 PM
