Whp Gains with Ctr pistons and JUn 3's???
I plan on putting some ctr pistons and jun 3 cams for my b18c1, I dynoed the car a while ago and got 169whp. I currently added a v-afc, not tunned and plan on adding ctr pistons and jun 3 cams. Does anyone know a estimate of how much whp will i be getting with the additon of cams and pistons? Has anyone had problems with running higher compression for daily driving? What other things should i get to enforce the drivability of the car for better reliablity in daily driving?- like change the rods? I have springs and retainers for the cams already. Thanks.
List of parts I have:
-Aem Adj. cam gears
-aem cold intake
-dc 4-2-1 header
-dc exhaust
-V-afc
-spoon chipped ecu
-msd ignition w/ blaster coil
-99 si tranny
-fuel regulator
-fuel pump
-type r cams
-jun flywheel
-act street/drag clutch
-Aem Adj. cam gears
-aem cold intake
-dc 4-2-1 header
-dc exhaust
-V-afc
-spoon chipped ecu
-99 si tranny
-fuel regulator
-fuel pump
-type r cams
-jun flywheel
you would be much happier w/ hondata.
i gained 16whp acoss the band over a p28 mugen/skunk2 chip.
i dyno'ed one hour only. my gears are still set at 0,0. i'm sure there are
more hp to be found if i spend another 1-2 hours on dyno.
this is not a must but if you have a dc jdm 4-1 (or better header), you'll
see more hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BanUglyImportModel »</TD></TR><TR><TD CLASS="quote">List of parts I have:
-Aem Adj. cam gears
-aem cold intake
-dc 4-2-1 header
-dc exhaust
-V-afc
-spoon chipped ecu
-99 si tranny
-fuel regulator
-fuel pump
-type r cams
-jun flywheel
see more hp.
-Aem Adj. cam gears
-aem cold intake
-dc 4-2-1 header
-dc exhaust
-V-afc
-spoon chipped ecu
-99 si tranny
-fuel regulator
-fuel pump
-type r cams
-jun flywheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BanUglyImportModel »</TD></TR><TR><TD CLASS="quote">yea that dc header and exhaust i have is crap i wanna get the comptech 4-1 header, invida exhaust and jg/elderbrock victer x manifold.</TD></TR></TABLE>
never heard of the comptech 4-1 header...which one are you talkin about?
whoops i meant 4-2-1, oh my couz has one and he selling the car so he taking some stuff out. since it has a 2.5" collector which exhaust application should i get for proper fit? Since I have a b18c1 on a 95 civic hatch. Should i be getting a ehaust to match the model of the car or the motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob.amd.inside. »</TD></TR><TR><TD CLASS="quote">comptech race header
do a search</TD></TR></TABLE>
ya well you might wanna explore the search button because i have the comptech race header and its 4-2-1 but thanks for comin out
curious on this subject...I thought GS-R rods stretch at high rpms (i.e. rpms JUN3's are made to run at). Wouldn't it be better to run Type R rods or something along those lines...
-Andrew
-Andrew
3s1k
May 28, 2010 04:15 PM
civiksi
Jun 9, 2002 09:27 AM
