Signs of bad axels?
Old Jun 27, 2003 | 02:04 PM
BlownREX's Avatar
Default Signs of bad axels?
ok i did a search. but didnt find anything close to my problem. well i a have a 90 crx hf with a b16a1 swap. well my problem is when i make left or right turns there are popping sounds coming from the wheel chamber. i have stock suspension also. any help to of help is welcome
Old Jun 27, 2003 | 02:05 PM
crucial si's Avatar
clicking?
Old Jun 27, 2003 | 02:06 PM
BlownREX's Avatar
Default Re: Signs of bad axels? (BlownREX)
yeah theres click sounds also
Old Jun 27, 2003 | 02:58 PM
STIBungy's Avatar
That's usually the symptons of a bad CV joint.
Old Jun 28, 2003 | 07:04 AM
jaxle's Avatar
look under your car by the offending wheel where the sounds are coming from. There is a ribbed boot on the end of the axle going into your wheel, this boot contains the cv joint and the grease. if the boot is ripped and there is grease allover you need a new axle.
Old Jun 28, 2003 | 07:37 AM
viprcr1's Avatar
Default Re: (jaxle)
wierd vibrations too
CrxGrin
Jan 20, 2013 08:53 PM
Taimaishuuyo
Transmission & Drivetrain
Jul 12, 2011 03:10 PM
timcali69
Aug 7, 2007 08:52 AM
Elmo1968
Oct 18, 2006 10:18 AM
futurefastguy
Mar 28, 2005 06:47 PM
