CR-V (1998) Technical Questions
Old Jun 27, 2003 | 12:46 PM
coquinn's Avatar
Default CR-V (1998) Technical Questions
I'm doing a timing belt/water pump on my mom's CR-V this weekend and had a few technical questions.
What is base timing? I'm assuming 16 +/-2 but wanted to be sure.
What are the valve adjustment specs? I figured I would do an adjustment while I'm in there.
What are the gaps on the spark plugs? I figured I would do these as well.
Thanks in advance - search engine was no help.
Old Jun 27, 2003 | 12:58 PM
JimBlake's Avatar
Default Re: CR-V (1998) Technical Questions (coquinn)
I think most of that stuff is printed on the emmissions sticker somewhere in the engine compartment?
Old Jun 27, 2003 | 05:25 PM
DaiJekBok's Avatar
Timing is 16 degrees BTDC +/- 2 degrees.
Valve clearance for intake is 0.08 - 0.12mm (0.003 - 0.006 inches); exhaust is 0.16 - 0.20mm (0.006 - 0.008 inches).
Spark plug gap is 1.0 - 1.1mm (0.039 - 0.043mm).
Have fun!
Tubbers530
Apr 20, 2018 09:51 AM
Roy Leyva
Engine Management and Tuning
Jan 10, 2017 04:19 PM
lolv8s
Dec 1, 2016 06:58 AM
coolswimmerjon
Sep 3, 2011 07:43 AM
