RoD KnoCK new bearings?
Old Jun 27, 2003 | 12:14 PM
untitled's Avatar
Default RoD KnoCK new bearings?
okay. i just dropped a b16a in my 91 teg. it ran fine at first but throwing a code 22 due to a wiring problem. with that fixed and no codes present i drove to see if vtec would crossover. it didnt. so i checked oil again. its full. now i can hear a slight knock when i first start the car. it seems like after the motor gets oil pressure it kinda drops off and goes silent. but when i would rev just a little (like to 2500-3000rpm) i could hear a knock from the bottom-end. i am saying its a rod knock. it seems very slight at the moment and i am not going to drive it anymore.
1) how much damage do you think has been caused?
2) could i just put new bearings in it and if doesnt knock or seize up i am good right?
3) do you think i will need the crank reground?
any opinions greatly appreciated.
Old Jun 27, 2003 | 01:50 PM
untitled's Avatar
Default Re: RoD KnoCK new bearings? (88crx91integra)
ttt
Old Jun 27, 2003 | 03:36 PM
HondaIntegraLS's Avatar
You won't know anything until you open it up and see if there was any scoring on the crank.
Old Jun 27, 2003 | 03:44 PM
.RJ's Avatar
.RJ
Your bottom end knocking doesnt have anything to do w/ vtec crossover (most likely), and if it is knocking you've spun a bearing and need to tear down the motor.
Check your TPS sensor/ground, MAP, coolant temp sensor, oil pressure sensor.. etc and if any of those are out of whack, vtec will not engage.
Old Jun 27, 2003 | 04:40 PM
untitled's Avatar
Default Re: RoD KnoCK new bearings? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Your bottom end knocking doesnt have anything to do w/ vtec crossover (most likely), and if it is knocking you've spun a bearing and need to tear down the motor.
Check your TPS sensor/ground, MAP, coolant temp sensor, oil pressure sensor.. etc and if any of those are out of whack, vtec will not engage.</TD></TR></TABLE>
oh but it does. vtec runs off oil pressure. if a rod has spun or is knocking the clearences are loose which decreases oil pressure.
Old Jun 27, 2003 | 06:34 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">oh but it does. vtec runs off oil pressure. if a rod has spun or is knocking the clearences are loose which decreases oil pressure.</TD></TR></TABLE>
Yes but thats not where your pressure sensor is located. Time to order some bearings and tear that chit down.
leem23vtec
Nov 4, 2010 04:34 PM
untitled
Jun 28, 2003 09:03 AM
untitled
Jun 28, 2003 08:59 AM
untitled
Jun 27, 2003 02:04 PM
untitled
Jun 27, 2003 01:51 PM
