A/C went out. What could be wrong??
I was driving with my boys to the shore and kept putting on the A/C then shutting it off. but it worked. We parked our cars and went out and did our thing. When we got back, the A/C would not kick on. What could this be? Could the compressor just dump out like that? Checked the belt, its fine too. Anything else???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jl74 »</TD></TR><TR><TD CLASS="quote">maybe you need to recharge your refrigerant</TD></TR></TABLE>
the belt is fine, It just doesnt kick on when i hit the a/c button. It did it last night before I went in the club, I came out and it dont work. Is there a fuse or somethin? i just dont see the compressor just kicking out just like that.
My AC went out cuz a rock hit the condensor and cracked one of the small piping in the front. This caused the freon to leak out. I would try rechargin it urself and to see if there's a leak somewhere. I had to replace the whole condensor to fix my problem. Good luck.
If there's no refridgerant in the lines the compressor will not turn on. Take it to a shop and have a test done on it, they'll fill the system with dye and see where its leaking out.
RJ
RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">If there's no refridgerant in the lines the compressor will not turn on. Take it to a shop and have a test done on it, they'll fill the system with dye and see where its leaking out.
RJ</TD></TR></TABLE>
Yea and until you get it checked out, don't try to turn on the A/C...you can damage your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nek0 »</TD></TR><TR><TD CLASS="quote">
don't try to turn on the A/C...you can damage your car.</TD></TR></TABLE>
I do believe, there is a pressure switch and other failsafes built
into the A/C system to prevent any damage caused by merely turning
the system "on". In others words, if it's broken, it won't turn on.
092eg6
Jul 25, 2009 11:56 AM
solsi2000
Apr 8, 2008 08:44 PM
90gs
16
Jul 15, 2005 06:40 PM
