Spark Plugs
Old Jun 27, 2003 | 09:29 AM
MyDragCar's Avatar
Default Spark Plugs
What kind of sparks plugs would be best to use with high compression, so that the plugs do not hit the pistons. Or would it be best to add additional spacers.
Old Jun 27, 2003 | 12:00 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Spark Plugs (allmotor7642)
Well on the assumption of a B-Series motor....NGK ZFR6F-11's. Or if you are a baller you could run Denso IK20's. I use to run OEM Denso's, but the above mentioned are great for 1/4 the price.
Old Jun 27, 2003 | 12:58 PM
Rocket's Avatar
Default Re: Spark Plugs (Mr Milano)
If you are worried about hitting the dome you should go with some retracted tip plugs, something like NGK part number 5671A-8 stock number 4554 (These are number 8's so they are pretty cold). These are pretty retracted so there's plenty of clearance for the piston dome.
Old Jun 27, 2003 | 04:16 PM
IN VTEC's Avatar
Default Re: Spark Plugs (Rocket)
I'm getting two stock number for the 8's. 2660 and 4554 seem to work. Maybe one of them is pre-gapped.
R5671A-7 (stock number 5587)
vs. BKR7EVX-11 (platinum-coated BKR plug)
Old Jun 27, 2003 | 04:50 PM
F1Spec's Avatar
NGK BKR7E
or
Bosch 4227
Gap at .35 for high compression B-series vtec motor.
Old Jun 27, 2003 | 05:37 PM
Rocket's Avatar
Default Re: Spark Plugs (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting two stock number for the 8's. 2660 and 4554 seem to work. Maybe one of them is pre-gapped.
Nice work IN VTEC. Looks like NGK has a bad *** website.
If you look closely at R5671A-7 you'll see that side electrode is only halfway over the center electrode. That's a good design, gives you mo power, believe it or not.
Old Jun 27, 2003 | 05:44 PM
Rocket's Avatar
IN VTEC, how did you find the part numbers on the NGK website?
Thanks.
Old Jun 28, 2003 | 05:32 AM
Mr Hammond's Avatar
a/k/a Jomo
I thought the BKR7E was a one step colder plug?
Old Jun 28, 2003 | 06:42 AM
IN VTEC's Avatar
I use a combination of clubplug.net's catalog and sparkplugs.com's stock/part number search.
Old Jun 28, 2003 | 11:52 AM
nobrakes's Avatar
any body seen erick aguilars spark plugs?????
Old Jul 1, 2003 | 11:02 PM
jdmcx's Avatar
Default Re: Spark Plugs (s2geezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2geezy &raquo;</TD></TR><TR><TD CLASS="quote">Gap at .35 for high compression B-series vtec motor.</TD></TR></TABLE>
is this true i have been doing .45
Old Jul 2, 2003 | 08:44 AM
IN VTEC's Avatar
Default Re: Spark Plugs (jdmcx)
I use a 1.3mm (.051") gap with the laser platinum plugs. The motor has 11.3 CR. No misfiring thus far.
Old Jul 2, 2003 | 01:08 PM
Rocket's Avatar
Default Re: Spark Plugs (nobrakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nobrakes &raquo;</TD></TR><TR><TD CLASS="quote">any body seen erick aguilars spark plugs????? </TD></TR></TABLE>
Maybe.
sneakychaos
Nov 8, 2008 04:47 PM
em1si
Sep 3, 2007 12:23 PM
lovitalracer
Feb 18, 2004 10:02 PM
jdmcx
Jul 3, 2003 10:13 PM
Westrock2000
Jan 26, 2003 09:58 AM
