Is the JDM ITR header support bracket necessary?
I'm talking about the bracket that supports the tail end of the JDM ITR header to the rear of the engine block. I understand that this bracket helps support the weight and movement of the exhaust system to prevent cracking but in your opinion is it necessary? I’d hate to break my header…
If necessary, where can I buy this bracket? Approximate cost?
To avoid confusion it’s the far left item in this picture:
Thanks for your time,
Aaron.
Aaron.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I think you'll find that the majority of people with the JDM ITR header are not using the bracket, and have no problems. </TD></TR></TABLE>
its only $20 - since offered from factory, i didn't see a reason not to use it http://www.inlinefour.com/25incolgas.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">I recommend against it since it only seems to lighten your pocket. </TD></TR></TABLE>
if you can afford a JDM ITR header, you can afford some 2 cent header bracket
If you have it already, I would use it. I wouldnt go out of myu way to buy it, though.
I had the JDM header on my ITR for a little over a year, and it was fin without the bracket.
