Upgraded calipers??
Old Jun 27, 2003 | 08:03 AM
C ronic's Avatar
Default Upgraded calipers??
I was wondering if any 4 piston calipers would fit on our Civic, (front, EK, ex trim)
Or any other really good front calipers... for under 300 bucks
Old Jun 27, 2003 | 08:25 AM
92sleepR's Avatar
New User
Default Re: Upgraded calipers?? (C ronic)
There are no stock (sliding) four piston calipers. If you switch to Integra knuckles you can use Legend/NSX 2 piston sliding calipers. You will need legend front discs as well.
The other option is the Wilwood (fixed) four piston calipers. The 11" kit from fastbrakes is the cheapest but be aware, NONE of the options I described are anywhere near $300 (try at least twice that)
Do a little searching through past posts and you will find out all you need to know.
Mike
Old Jun 27, 2003 | 02:15 PM
B16b2b's Avatar
you could use a gsr caliper. it would fit the same diameter rotor, but the piston is actually slightly bigger.
Honda Type R
Suspension & Brakes
Jun 20, 2015 01:20 PM
MiamiEgGSr
Jun 4, 2008 12:26 PM
rollercosta123
Jan 11, 2007 04:03 PM
ijjz
Aug 25, 2002 10:24 AM
