JDM ITR Header -- Getting welds cleaned up
Old Jun 27, 2003 | 07:46 AM
jond's Avatar
Default JDM ITR Header -- Getting welds cleaned up
Has anyone had the welds on their JDM ITR Header fixed?
Mine where the pipes are welded to the piece that bolts to the block, it looks like the pipes were welded from the inside, and it looks really bad. Like a friday at 4:15 job.
I'm wondering if it would be safe to just grind down the welds, or if I took it to a welder would it be a simple 10 minute job for them(dont want to spend too much money on my $300 header)
Old Jun 27, 2003 | 07:48 AM
shivers's Avatar
Default Re: JDM ITR Header -- Getting welds cleaned up (jond)
http://www.sandmracing.com/m_e02_jdmheader.html
Old Jun 27, 2003 | 08:02 AM
jond's Avatar
Default Re: JDM ITR Header -- Getting welds cleaned up (ajm_00Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajm_00Si &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sandmracing.com/m_e02_jdmheader.html</TD></TR></TABLE>
Perfect! Thanks!
Now I guess I just need to find a welder.
Old Jun 27, 2003 | 08:15 AM
onyx00's Avatar
I wanted to do this but I got my header Jethot coated first. to me. Oh well.
Old Jun 27, 2003 | 08:18 AM
GokuSSJ4's Avatar
what type of drill bit (or sander ) would you use to perform this grinding job .?
Old Jun 27, 2003 | 08:24 AM
jond's Avatar
Default Re: JDM ITR Header -- Getting welds cleaned up (Spoon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 &raquo;</TD></TR><TR><TD CLASS="quote">what type of drill bit (or sander ) would you use to perform this grinding job .?</TD></TR></TABLE>
Dont know yet. I might see how well a dremil works on it, but I kinda doubt its going to do it. Might go by sears today and see what kind of things they have that will hook up to a regular drill.
Old Jun 27, 2003 | 08:25 AM
onyx00's Avatar
You can use a dremel with the sanding cylinder attachment.
Old Jun 27, 2003 | 08:27 AM
jond's Avatar
Default Re: JDM ITR Header -- Getting welds cleaned up (onyx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">You can use a dremel with the sanding cylinder attachment.</TD></TR></TABLE>
I'll try it. The only dremel I have access to is battery powered, so its going to take a few days...
Old Jul 22, 2003 | 09:48 AM
Seedc2's Avatar
omg............... that jdm header looks ******* beautiful! how much did it cost to coat it?
that would have been cool if there was some text for the install because im doing this later today.. (once the smsp cat arrives )
Old Jul 22, 2003 | 10:06 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">I'll try it. The only dremel I have access to is battery powered, so its going to take a few days...</TD></TR></TABLE>use a air powered die grinder... you will thank me.
it took me ~5 min to remove part of the welds (did not re-weld the outside) back home.
drive to Appomattox and I will meet you to grind dat chit.
Mikizzle
May 3, 2004 11:39 PM
ChopstiX
Feb 4, 2004 10:50 AM
slimbo
Nov 23, 2003 10:26 AM
Lonerider
Jul 2, 2003 01:34 AM
