Roller Rocker arms for Dseries what motor and will they fit the D16Z6 or D16Y8 motor?
I saw a post about roller rocker arms for a VX or what motor it came from just want to know if they will work in the D16Y8 or D16Z6 motor anyone have a set and know if they work 100%??
The factory roller rockers for d-series motors came in the Civic HX and maybe the VX...not sure about the VX. Either way they will not swap into the other d-series heads without swapping the cam over also.
The reason for this is because the roller rockers are based on a 2 lobe design and not a 3 lobe like the other d-series vtec heads.
The only way I can see using the factory roller rockers would be if you get a custom ground HX or VX cam.
Hope all this is correct, i'm going from memory here.
PauL
PauL
Im wondering if we can use the EXH rocker arms from the roller vs motor and the D16Z6 stock 3 lobe on the D16Z6 head and cam
