Roller Rocker arms for Dseries what motor and will they fit the D16Z6 or D16Y8 motor?
I saw a post about roller rocker arms for a VX or what motor it came from just want to know if they will work in the D16Y8 or D16Z6 motor anyone have a set and know if they work 100%??
Re: Roller Rocker arms for Dseries what motor and will they fit the D16Z6 or D16Y8 motor? (JDMCRX)
The factory roller rockers for d-series motors came in the Civic HX and maybe the VX...not sure about the VX. Either way they will not swap into the other d-series heads without swapping the cam over also.
The reason for this is because the roller rockers are based on a 2 lobe design and not a 3 lobe like the other d-series vtec heads.
The only way I can see using the factory roller rockers would be if you get a custom ground HX or VX cam.
Hope all this is correct, i'm going from memory here.
PauL
PauL
