can I install blue box and 255 pump before turbo? will my car run?
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I want to get my turbo kit installed, but I don't want to pay extra for the little things like fuel pump and blue box wiring. If i install them both, will my car bog to death on the drive to the shop since it's not boosted yet?
You want shop to install your turbo right?..then let them do it..dont give them the blue box or fuel pump..you can run Vacuum mode after turbo install..(no boost) then install pump, blue box after; then run boost...
Well that roost is not reliable though..cause think about it, if you have the shop install; the shop is responsible for your install right..If you did somethiing wrong with the blue box and blow or f*ck something up, I dont think the shop cover it for you...better off pay little more then let the shop worry about it..and bettter and quality job..
