??wat are helper springs for??
Old Jun 26, 2003 | 09:24 PM
UdontknowME's Avatar
Default ??wat are helper springs for??
wat are they for??will it slam my car more if i remove em and wat happens if i take em out??please post up..THANKS!
Old Jun 27, 2003 | 03:52 PM
Default Re: ??wat are helper springs for?? (fork sports)
nobody knows???come on techs!!
Old Jun 28, 2003 | 05:26 PM
no one??
Old Jun 29, 2003 | 10:13 AM
Mista Bone's Avatar
D Tranny Guru
Search Eibach Tender Springs
Old Jun 29, 2003 | 10:34 AM
NonovUrbizniz's Avatar
Loved
Default Re: ??wat are helper springs for?? (Mista Bone)
So after he does that and gets zero results what does he do?...
I searched google and found this...
The Helper spring is used to prevent the Main spring from becoming loose in the spring seat when the wheel is at full droop. The Helper spring unlike the Tender spring, has very little spring rate and therefore, has no effect on the suspension characteristics of the vehicles. Up to 50mm of spring-to-perch gap can be covered with the use of a Helper spring.
Old Jun 29, 2003 | 02:48 PM
STIBungy's Avatar
Pretty much to keep the main springs from falling out of place. My GC springs fall out of place everytime I lift the car up on a jack. It's a paing cuz I have to make sure they're lined up right again the upper mount before I fully lower the car.
If you dont want them, I'll take them.
i-VTEC_do_you
Suspension & Brakes
Mar 13, 2011 05:31 AM
Naturally Aspirated
Sep 21, 2004 06:23 PM
Stag 2000
Honda S2000
12
Feb 20, 2003 07:41 PM
