I think i blew a fuse NEED help!!!
Old Jun 26, 2003 | 09:17 PM
Rhythm Racer's Avatar
Default I think i blew a fuse NEED help!!!
well i was driving and my friend was behind me and he called my cell and said my brake lights wernt working....so i was like damn ill pull over and make sure everything is connected, on my way pulling into the gas station i went to honk my horn and the horn didint work either you think this is fuse related!!!!
Old Jun 26, 2003 | 09:26 PM
Default Re: I think i blew a fuse NEED help!!! (Rhythm Racer)
anyone
Old Jun 26, 2003 | 09:27 PM
Wilson_'s Avatar
brake lights or tail lights?
Old Jun 26, 2003 | 09:29 PM
andrew dc's Avatar
Default Re: I think i blew a fuse NEED help!!! (Silverstone00Si)
check the fuse box under the steering wheel.... read the chart and check for your fuse.. if still confused, pull all fuses and replace blown fuse
Old Jun 26, 2003 | 09:34 PM
Default Re: I think i blew a fuse NEED help!!! (andrew ef)
brake lights
Old Jun 26, 2003 | 09:43 PM
COMplex.'s Avatar
also, check the underhood fuses as well. i'm almost positive there is a brake light fuse under there too.
does the horn relay still click when you press it?
Old Jun 26, 2003 | 10:58 PM
BrynnTheSlut's Avatar
while your at it just replace all the fuses for fun! hahah!
Old Jun 27, 2003 | 01:15 AM
stripes777's Avatar
u dont need to do that man, jus look for the busted fuse and replace it
Old Jun 27, 2003 | 02:31 AM
AWD: Jeff's Avatar
Default Re: (stripes777)
you can tell if the fuse is busted if it looks burnt or if the thin metal is split into two seperate parts.
Old Jun 27, 2003 | 09:22 AM
Default Re: (Dohc93hatch)
Thanks for all the feed back but i think im just gonna go ahead and replace all the fuses... fuses are cheep and the fuses havint been replaced since 96 so what the hell!!!! thanks
Old Jun 27, 2003 | 10:00 AM
eg6turbo's Avatar
Default Re: (Rhythm Racer)
the horn fuse under the hood controls the brake lights too...what happens sometimes is that if the horn wires gets pinched it'll blow that fuse and end result losing horn and brake light...2nd gen and 3rd gen integras are like that i believe
Old Jun 27, 2003 | 10:46 AM
ImportHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythm Racer &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the feed back but i think im just gonna go ahead and replace all the fuses... fuses are cheep and the fuses havint been replaced since 96 so what the hell!!!! thanks</TD></TR></TABLE>
Really not neccesary to replace them all, but do what you will. Just look for the blown one and replace it with the right amperage fuse.
Yager-
Dru-Si
Mar 21, 2010 06:12 PM
tdubbebawllin
Jul 29, 2008 01:34 PM
Bobby808
Apr 10, 2005 11:13 AM
OptimusPrimeX
Feb 3, 2004 02:37 PM
