D16Y7 motor in my 93 vx hatch.. it wont stop overheating no matter what! HELP ME!
i put a 99 Y7 in my hatch, it over heats repeatedly, i have tried everything--
i hollowed out the thermostat-
i then ran a switch to the radiator fan--
i put a GSR radiator in ----
ran a switch to BOTH fans on the gsr radiator--
the car overheats like when i drive, as i give it gas the temp gauge just goes up rapidly---
lots of pressure builds up and the hose that goes to the head right next to the temp gauge plug - under the distribitor thats the one that all the steam comes out thats where the pressure is let out--
i opened the radidator cap and it seems as though the water is pumping---
i installed a Y8 in a 93 four door, he has the same problem.. im stuck... can anybody help..
please....
please....
what I think you should do the see if the coolant is going though your engine, by touching the lower hoses. It should be a warm ( hot).
also the radial fan can blow two way. If fan is behind radial, then it should blow toward the engine. good luck
well thats the thing-- some days my car will run fine, and then some days like u said the lower hose will be cold--- u think i have a water pump problem?
i just put the motor in 2 weeks ago- it has 18k miles on it
yea also i think the fan blows towarrs the engine--- well both of them-- on the gsr radiator
ok-- well its not the gauge because the water was all steaming out of one of the hoses -- so it was really hot-
i didnt notice when i put the new radiator in... that the drain thing at the bottom was loose lol---- also the hose that was steaming had a small hole in it-- like a screw driver puncture-- i cut the hose short, fit that up-- tightened the drain plug added water now the tempature stays on Cold-- all the way cold--
should i go ahead and put my thermostat back in?? or will it bother the motor to let it run cold--- it ran all good yesterday but who knows it might run crappy again today-- but i think it was the hose because it was the heater hose, i dont think any water was even getting to my lower hose-- thanks alot-- peace
TeamInertia619
Sep 28, 2015 05:42 PM
marebear1984
Sep 17, 2011 11:12 PM
