Mini-me questions and alternator belt question!!!!
Old Jun 26, 2003 | 04:01 PM
RacinMasonC's Avatar
Default Mini-me questions and alternator belt question!!!!
Okay what can i use for the VTEC engagement with the Si wire harness, Si IM and TB, and Si distributor from 88 CRX si??? could i use a RPM activated switch with the pill kits? some person on HAN said i will NEED the 92-95 civic EX/Si ECU. what do i need?
also when i start up my engine the alternator belt (i believe) is squeaking a HELL OF A LOT!!!! untill after 10-15 seconds or if i rev it up to 2500rpm and let off, then its all normal.. the belt is as tight as i can get it with a LITTLE freeplay in the belt.. i was just wondering if i need a new belt or how can i fix the squeaking? thanks guys!
Grenade2k7
Jun 21, 2007 07:04 PM
failed
Sep 4, 2005 05:59 AM
Kato7997
Feb 23, 2003 11:23 AM
