Just bought a civic with a turbo
Old Jun 26, 2003 | 04:01 PM
vtec95's Avatar
Default Just bought a civic with a turbo
Guys I just bought a 95 ex with a greddy turbo in it, and noticed a little leakage from the oil pan where the turbo was put in. Is there anything to do to make it stop leaking? Something simple? Please help! Thanks
Old Jun 26, 2003 | 04:38 PM
mamaboy's Avatar
Default Re: Just bought a civic with a turbo (vtec95)
jb weld...or better yet drain your oil....take off the fitting and go get it welded on....i'm sure you can do all that at the muffler shop
Old Jun 26, 2003 | 04:40 PM
MiraiZ's Avatar
Are you talking about the oil return line?
Just cleanit as best you can, maybe spray some brake cleaner to get the oil off of the pan and fitting.
Use some copper insulation that is safe for autos, or maybe JB weld to seal the leak.
Old Jun 27, 2003 | 01:59 PM
vtec95's Avatar
Default Re: Just bought a civic with a turbo (MiraiZ)
The fitting is on the oil pan already and it leakes where the two meet. I will try the jb weld, but in the mean time any other suggestions?
Old Jun 27, 2003 | 05:56 PM
rioninja's Avatar
Cmon, this is common sense.
Old Jun 27, 2003 | 08:02 PM
DeepSi's Avatar
the jb weld is probably the easiest and cheapest method. Not really hard. Just get a package from Home Depot and mix it together. clean the spot and apply. not hard at all.
Old Jun 27, 2003 | 08:48 PM
TheAntiEndz0r's Avatar
Default Re: Just bought a civic with a turbo (DeepSi)
OT:
Where do you buy JB Weld? Is JB Weld what the actual product is called, or is there multiple JB Welds under different names?
Old Jun 27, 2003 | 08:49 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeepSi &raquo;</TD></TR><TR><TD CLASS="quote">the jb weld is probably the easiest and cheapest method. Not really hard. Just get a package from Home Depot and mix it together. clean the spot and apply. not hard at all.</TD></TR></TABLE>
WOW home depot, says right above
Old Jun 27, 2003 | 08:52 PM
gritsak's Avatar
they already gave you about the only suggestions you can do..
1. get it welded (or re-welded if it already is)
2. use jb-weld
i would just use jb weld...drain the oil first..clean all around everything REALLY good, apply the jb weld all around it and let it dry at least overnight (12-24hrs)
that should fix it as long as you got a good seal with the jb weld
justYncredible
Feb 8, 2012 10:20 AM
MalcolmV8
Dec 5, 2011 05:29 PM
dart2.2
Jul 25, 2008 07:01 AM
dunkd
Mar 8, 2004 09:07 PM
orange.honda
May 6, 2003 04:14 AM
