How much more will i benifit from GSR cams over B16 cams?
Old Jun 26, 2003 | 03:11 PM
SIReg9's Avatar
Default How much more will i benifit from GSR cams over B16 cams?
I heard everyone runs GSR cams in their turbo setup? Will it be worth me gettin GSR cams and ditching my B16's? or will they be about the same?
You guys know better than i do...lemme know. thanks alot guys!
Old Jul 10, 2003 | 05:01 AM
JDiMageDC2's Avatar
Default Re: How much more will i benifit from GSR cams over B16 cams? (SIReg9)
I believe those cams are the same.
Old Jul 10, 2003 | 05:05 AM
RacerXI's Avatar
Default Re: How much more will i benifit from GSR cams over B16 cams? (GSRTUNR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRTUNR &raquo;</TD></TR><TR><TD CLASS="quote">I believe those cams are the same.</TD></TR></TABLE>
Those cams are not the same. I have them in my car and i think they are hurting my performance. i've got a 8psi jackson with bolt-ons. I think with a mild setup b16's should work fine.
Old Jul 10, 2003 | 05:08 AM
onetwothree's Avatar
Nope.
Cams Measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Old Jul 10, 2003 | 06:25 AM
VTC_CiViC's Avatar
Default Re: How much more will i benifit from GSR cams over B16 cams? (onetwothree)
So really, the lift is nearly identical, it's the much longer duration which gives the GSR cams the edge..
Old Jul 10, 2003 | 07:07 AM
abraunb16's Avatar
New User
Default Re: How much more will i benifit from GSR cams over B16 cams? (VTC_CiViC)
Just swapping the cams I made an intial 16 whp gain over the B16's. That's just swapping cams and using same program. Then fine tuned the map and numbers grew. GSR cams are a cheaper alternative than aftermarket, they can be had for $50-$100 used.
Old Jul 10, 2003 | 10:20 AM
Default Re: How much more will i benifit from GSR cams over B16 cams? (abraunb16)
I got a pair for $100 shipped anywhere. Lzbrown@hotmail.com no paypal or pics
Old Jul 10, 2003 | 10:25 AM
alpha's Avatar
I have seen three car's dynoed with B16a camshaft and after B18c1 camshafts. All three made the same gain but obviously their powerbands were different. All of them gained 8whp and 1ft-lb PEAK.
Old Jul 10, 2003 | 11:06 AM
SIReg9's Avatar
Default Re: (0x64)
So all in all, they will be worth me adding them. I wont be doing a mild setup. a lil more agressive. I can most likely find a set local i hope
Old Jul 10, 2003 | 11:17 AM
boosted92's Avatar
Default Re: (SIReg9)
Would a CTR Intake cam and a GSR exhaust cam be a good setup for turbo?
Old Aug 13, 2003 | 03:10 PM
roadawg's Avatar
Default Re: (boosted92)
CTR intake cam has 11.5 mm of lift and 243 degrees of duration on the intake cam
and 235 degrees of duration on the exhaust cam.
CTR cams are your best bet, if you are using factory Honda cams.
Old Aug 13, 2003 | 03:18 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onetwothree &raquo;</TD></TR><TR><TD CLASS="quote">Nope.
Civic Si(1999 Spec)
Integra GS-R
These are specs from Crower's site
Stock Specs from Civic Si Int-265 mid Exh-267 mid Int-219 mid Exh-214 mid Int-.412 mid Exh-.379 mid
Stock Specs from GSR Int-274 mid Exh-276 mid Int-230 mid Exh-216 mid Int-.423 mid Exh-.378 mid
Stock Specs from Civic Type R (JDM Spec) Int-278 mid Exh-280 mid Int-233 mid Exh-224 mid Int-.449 mid Exh-.417 mid
spoolinvtec54
Aug 21, 2011 03:24 PM
wearyfurball
16
Feb 19, 2008 08:54 AM
