fuel pump swapping
Old Jun 26, 2003 | 02:57 PM
KRiS1's Avatar
Default fuel pump swapping
Id like to replace my failing fuel pump in my 94 Si with a newer gsr/itr unit. Is this a plug&play afair?
Old Jun 26, 2003 | 03:06 PM
poison's Avatar
Default Re: fuel pump swapping (POS Hatchback)
factory fuel pump to an ITR or GSR should be just the same.
It's very simple to do. you just remove the chrome plate, unplug the 2 harnesses, then there is about eight or so 10 mm bolts. Disconnect the hoses, remove the pump and reverse the process
You also might want to have a rag just incase fuel pressure is still up there. I would wait a while after driving the car before you change anything though.
Old Jun 26, 2003 | 03:55 PM
KRiS1's Avatar
Default Re: fuel pump swapping (poison)
Thanks!
jdmfoglights
Feb 6, 2014 06:56 AM
o2flow.net
Oct 1, 2006 08:55 AM
wizzards581
Mar 22, 2004 04:09 PM
Rice Ball
Dec 4, 2003 09:54 AM
