90 integra release bearing same as 92 1.7l?
Old Jun 26, 2003 | 02:18 PM
kanzenr91si's Avatar
Default 90 integra throw out bearing same as 92 1.7l?
was wondering if my new throw out bearing for a 90-91 1.8L integra tranny will fit in a 92-93 1.7L tranny????
Old Jun 26, 2003 | 05:39 PM
Rocket's Avatar
Default Re: 90 integra throw out bearing same as 92 1.7l? (kanzenr91si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kanzenr91si &raquo;</TD></TR><TR><TD CLASS="quote">was wondering if my new throw out bearing for a 90-91 1.8L integra tranny will fit in a 92-93 1.7L tranny????</TD></TR></TABLE>
Yeah it should work fine.
Old Jun 26, 2003 | 06:30 PM
StorminMatt's Avatar
NO!!!!!!!!!!
The YS1 (1992-1993 Integra) transmissions use a similar input shaft to the hydraulic transmissions. Simply put, it is larger. And so is the sleeve upon which the release bearing rides. A 1990-1991 release bearing will NOT fit a 1992-1993 transmission.
Old Jun 26, 2003 | 07:25 PM
Default Re: 90 integra throw out bearing same as 92 1.7l? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">NO!!!!!!!!!!
The YS1 (1992-1993 Integra) transmissions use a similar input shaft to the hydraulic transmissions. Simply put, it is larger. And so is the sleeve upon which the release bearing rides. A 1990-1991 release bearing will NOT fit a 1992-1993 transmission.</TD></TR></TABLE>
this is what i thought, but so far ive got 2 responses for yes and 1 for no. i guess ill wait till my tranny comes and find out for sure.
Old Jun 27, 2003 | 12:42 PM
Rocket's Avatar
As far as I know we at Action clutch don't use a different bearing for 90-91 v. 92-93 trannies.
The TO bearing goes over a plastich collar on the tranny. The input shaft is much too small to make any difference. Although the major diameter of the splines is 1mm bigger.
You can test if your TO bearing works on the new tranny by just installing it on the new tranny and moving the release arm back and forth.
Modified by Rocket at 10:11 PM 6/27/2003
Modified by Rocket at 10:53 PM 6/27/2003
Old Jun 27, 2003 | 05:30 PM
Default Re: 90 integra throw out bearing same as 92 1.7l? (Rocket)
coo ill find out for sure in about a week. while this is here the clutch is different though right? pretty sure about this but figured ill doubel check.
Old Jun 27, 2003 | 05:34 PM
Rocket's Avatar
You'll need a different disc. The pressure plate is compatable across all B-series.
Nicaraguense13
Aug 30, 2006 09:41 AM
Crafte
Apr 2, 2006 07:38 PM
tech1340
Dec 10, 2003 07:14 PM
